DSP components not active after purchase
DavidBotha_1
Flowcode v9 DSP components not active after purchase
Post by DavidBotha_1 »
Hello. I have an issue with my DSP components not being active, as well an error with the AVR compiler. The components were purchased some time ago and have only started to try and work with the components recently. Any help is appreciated.
Has thanked: 231 times
Been thanked: 392 times
Re: DSP components not active after purchase
I have checked your licence and it seems the DSP components and AVR are both active. Have you tried re-activating your licence within Flowcode as per this FAQ?
IMPORTANT: AFTER YOU HAVE ACTIVATED YOUR KEY YOU MUST REAPPLY YOUR LICENCE USING YOUR USERNAME AND PASSWORD WITHIN FLOWCODE.
To do this, go to the Manage section in the Licensing within Flowcode, then click "My Flowcode License" and type in your username and password again.
If that does not solve the issue, please show what you are seeing within the "Licensing...View" and "Licensing...Licensing" screens.
DavidBotha_1
Hi Steve.
Thank you for your quick response. Your advise has sorted the problem with the DSP.
