COMPONENT ADC INPUT (POTENTIOMETER) NOT WORK-FC10
SILVESTROS
Has thanked: 32 times
Been thanked: 2 times
Post by SILVESTROS »
In input components / ADC Input / Potentiometer and Pot Slider , I can't set analog input in Connections at Properties ..I get "unconnected" that not change...so I can't connect input pin of mcu (PIC16F628A) . Any idea on how to solve that? Thanks.
Basil
Has thanked: 724 times
Been thanked: 783 times
Re: COMPONENT ADC INPUT (POTENTIOMETER) NOT WORK-FC10
When you choose the target, of 16F628A, scroll along and it will show there are no ADCs available for that target.
No ADC 16F628A.png (19.97 KiB) Viewed 2228 times
The 16F828/A has a comparator, which is why you can see AN references.
It can be confusing.
You will need to select a target that has onboard ADC.
