Hi to all
I use the i2c multiplexer and it works great. Very convenient to connect 8 different temperature sensors boards.
with Flowcode just one loop and read all sensors in an array.
But this i2c multiplexer module only works in i2c software mode.
Then I have a question about the address bit propertis. How do I configure this? This is described differently in the help
ESP32 and i2c multiplexer TCA9548A
- Has thanked: 234 times
- Been thanked: 252 times
Re: ESP32 and i2c multiplexer TCA9548A
Hi Martin
Now I have understood. With the multiplexer TCA9548A I can select 1 of the 8 “qwii i2c connectors”.
But I can also use 8 different multiplexers TCA9548A with these A2, A1, A0. Address selector.
With the other component I simply select the address in hex if I use several TCA9548A.
I will test the other component if i2c hardware works and post the result here.
how to change change the adress from the TCA9548A on the sparkfun device
Hi Martin
The other component also works well, but only in software mode I2c bus.
Do you have any idea why the three components only work in software mode?
