Hola,
He realizado lo indicado por Martin en el post del enlace siguiente:
viewtopic.php?f=3&t=2663
Dentro de la macro, que se llama del componente "intervalo", tengo un bloque de cálculo y ejecutandose correctamente lo indicado en: salida=!salida y salida-> C1.
Pero dentro del bloque de calculo tambies existe segundos=segundos+1 y este cálculo no se actualiza.
Adjunto en fichero
¿A que puede ser?
Gracias de antemano por la ayuda.
I have done what Martin indicated in the post linked below.
Within the macro, which is called the "interval" component, I have a calculation block and the following is executed correctly: output=!output and output-> C1.
But within the calculation block there is also seconds=seconds+1 and this calculation is not updated.
Attached in file
What could it be?
Thanks in advance for the help.
The variable in the "Interval" component is not updated
Carmelo
- Has thanked: 57 times
- Been thanked: 4 times
- Con Intervalo de timer.fcfx
- (21.79 KiB) Downloaded 371 times
- Has thanked: 590 times
- Been thanked: 778 times
Re: The variable in the "Interval" component is not updated
This bug is currently only in the simulation engine and will run as expected on the microcontroller hardware. We have managed to replicate the issue and are investigating.
