Esp32 Display board
Chadb
Has thanked: 32 times
Flowcode v10 Esp32 Display board
Post by Chadb »
HI I have an esp board with a display.
https://www.amazon.com/DIYmalls-ESP-WRO ... C94&sr=8-1
I have managed to get most everything working but the touch controller.
They are wired to :
TOUCH:
CTP_SDA.33
CTP_SCL.32
CTP_RST.25
CTP_INT.21 * This is shorted to gnd on my version.
You can cut the trace and wire it to R25 Pad.
33 and 32 do not exist in the pin configurations in flow code.
Any ideas?
Thanks,
Chad
Has thanked: 645 times
Been thanked: 855 times
Re: Esp32 Display board
Hi Chad,
32 is pin B0 and 33 is pin B1, hope this helps :D
This too might be interesting for you.
viewtopic.php?p=16701#p16701
Chadb
Post by Chadb »
Thanks, I used those numbers and I still can't get anything out of the touch. Right now, I am just doing a sample sensor looking for a touch and if I get one I am trying to light a LED. It simulates ok, but I can't get anything out of the hardware. I have tried 100k 400k i2c rate, I am using i2c2 because 1 is used on a mcp23017. I have tried single ended and differential. I am not using the interrupt pin. My board has it hardwired to GND. That should give a 0x5d address. I have tried both. Still nothing.
Could you please take a look at the GT911 component?
Any other suggestions?
Thanks,
chad
Chadb
Post by Chadb »
Bump.
Hi Chad,
I've ordered one so I'll investigate for you.
Chadb
Post by Chadb »
Cool, The documentation sucks, so here is a head start.
LCD: ST7796
MOSI-A.13
MISO-A.12
CLK-A.14
CS-A.15
D/C-A.2
RST- N/A Tied to RST BTN PIN
LED BACKLIGHT -A.27
TOUCH: GT911
CTP_SDA.33 ==B1
CTP_SCL.32 ==B0
CTP_RST.25
CTP_INT.21 * This is shorted to board on my version.
SPEAKER sound -26
CN1 I2C:
SDA 21
SCL 22
Red LED: 4
Green LED 16
Blue LED 17
Photocell An6 / io 34
Chadb
Post by Chadb »
WingNut
Has thanked: 56 times
Been thanked: 43 times
Post by WingNut »
Interesting device. I wonder how hard it would be to integrate it into a display for home assistant
It's taken me all day to track down the cause but hopefully resolved for you now.
The latest GT911 component in the library updates should solve the issue.
Here's my working test program.
GLCD_Test_GT911.fcfx
(20.43 KiB) Downloaded 619 times
Chadb
Post by Chadb »
Yep, that works, Even have the multitouch going. Thanks!!! What was wrong?
Chad
