Hi team,
I am stuck with my project since the upgrade from STM32F051K8 to STM32F303K8 (pin compatible) is not possible. A revision of PCB at this stage is not cost effective.
Tried updating FC10 and the library too but still the following were missing for the STM32F303K8 chip.
1) TIMERS --> 15,16 & 17
2) Analog inputs 12bit --> AN11 & 12
Please help me out on this issue.
Thanks in advance
Ramesh
Missing TIMs & AIs for 32F303Nucleo32
RTJNair
- Has thanked: 629 times
- Been thanked: 836 times
Re: Missing TIMs & AIs for 32F303Nucleo32
Hello Ramesh,
The timers should be there in v10, I've just checked the definition file and they are there. Please let us know if they are still missing for you.
The analogue inputs are not there for the K (32-pin) version of the 32F051 but are there for the R (64 pin) version as this has more pins.
Hi Ben,
Tried but still couldn't find it.
You may please refer to the following (F303K8),
Ramesh
Ramesh
Hi Ben,
Tried but couldn't find it for the target chip F303K8. You may please refer to the following images from it's spec.
Thanks,
Ramesh
Thanks,
Ramesh
Hi Ben,
Somehow, the images are not visible in the above post. Please copy the image address/link and open it in a new browser tab to make it visible.
I opened the FCD for F303K8 but saw that it wasn't tallying with the chip definition. Couple of things I noted were,
1) the timers, only two timers defined, TIMR2 & 3
2) Analog Inputs, only the A-port defined but not the B-port.
Please look into this and expecting your earliest help.
Thanks,
Ramesh
Thanks,
Ramesh
Aha ok you'r looking at the 303K8, I read your first message as it wasn't possible to move to this chip.
Right let me look again.
Hopefully resolved for you now. Many thanks for letting us know.
Many thanks Ben and hope you will roll out the update for 303K8 very soon..
Ramesh
Ramesh
Should be there for you now if you goto Help -> Check for updates.
Hi Ben,
I tried updating the library but couldn't find anything different and is still the same as before.
Also, the update, mostly for PIC chips didn't contain anything for the STM 303k8 (fcdx).
Thanks,
Ramesh
Thanks,
Ramesh
