Page 59 of the Locktronics Curriculum CP8408 (Automotive ECU Architechure and Logic) mentions that the program in the MicroECU LK8886 can be changed using Mloader. If I want to restore the original firmware, I require at least the hex file (Automotive PIC ECU Firmware.hex ?).
Where do I download this file from the Matrix website?
Is the Automotive Solution LK4221-2 with the PICmicro LK4690L still available, or has it been replaced by the LK1800 solution with the MicroECU LK8886?
Locktronics MicroECU - firmware
DonBoscoWoluwe
- Has thanked: 616 times
- Been thanked: 815 times
Re: Locktronics MicroECU - firmware
This is a good place to start with the firmware download.
https://www.matrixtsl.com/locktronics/resources/
I'll ask about the solution for you.
The LK4221-2 and the LK4690L are now both discontinued and I don’t believe they have a direct replacement.
The LK1800 is almost a separate and different kit … but the LK1800 is available.
DonBoscoWoluwe
The original firmware for the MicroECU LK8886 (Automotive PIC ECU Firmware.hex ?) is not available on https://www.matrixtsl.com/locktronics/resources/
I beleive this is what you're after.
I'll get them put on the website for you.
