A serious problem:ServoMotor is not working properly
Been thanked: 3 times
Post by 17712885438 »
V10 compilation HEX file is all right. But downloading it to the chip is not right. But downloading everything in V8 is ok. I tried PIC series, arduino series. V10 does not work properly after downloading.Attach example
ServoMotor.fcfx
(12.62 KiB) Downloaded 177 times
ServoMotor.fcfx
help me
Servo motor is not working properly when the hex file is loaded into proteus, and theServo motor does not turn when the hex file downloaded into the chip. But in V8 it all works fine. Please help me.
Flowcode1.fcfx
(12.66 KiB) Downloaded 191 times
Has thanked: 789 times
Been thanked: 849 times
Re: A serious problem:ServoMotor is not working properly
Hello, sorry for the delay in replying.
There is a bug with the latest servo.
To get the servo working again, you will need to rollback from v7 to v6.
Instructions can be found within the Wiki here.
Flowcode v10 Re: A serious problem:ServoMotor is not working properly
I have fixed the servo controller.
There are additional functions now which are MoveToAngle & AutoMoveToAngle
To try the Servo Controller out, before it's push onto the database:
%ProgramData%\MatrixTSL\FlowcodeV10\Components
Place the attached component.
Servo_Controller.fcpx
(19.3 KiB) Downloaded 134 times
I can confirm, a working servo controller component has been pushed onto the component database.
This includes the two extra functions.
