Seven Segment Driver ICs - What is the best?
jay_dee
Has thanked: 99 times
Been thanked: 69 times
Post by jay_dee »
Yet another possible customer project, unusally they actually have a sensible budget.
Driver IC for Seven segment displays.
What is considered the preffered driver chip ? I see there are a few varients already supported by flowcode components.
Just looking for Numbers 0-9 and it will be sets of individual seven segment elements, not arrays of 4 digits as is usually found.
The project will contain 30 seperate 7 seg digits.
+ 26 LED lamps and 4 classic LEDs. Look up an Aston series 1 lagonda dash board...its a spaceship of a car from the late 70s
thanks for any guidance. J.
Has thanked: 839 times
Been thanked: 205 times
Re: Seven Segment Driver ICs - What is the best?
Post by jgu1 »
Hi /J
I don't really know what you are going to do with the project and what you want, but as you mention yourself, there are several in flowcode.
I know from earlier where you assembled everything yourself with Cmos and TTL circuits I have used sevensegment driver which an Lacth, counter, 4 bit, select Anode/Catode ect. as you can use with FC10 and Arduino and Pic.
Have a look at CD4543, BCD and 4026 counter, MC14558 seach for the data on the internet :D
Hope it is this could be usefull ;)
Br Jorgen
Has thanked: 442 times
Been thanked: 661 times
Hi JayDee
You could probably get an army of free workers to help on that Lagonda. No moving parts other than the steering wheel if I remember.
Has thanked: 234 times
Been thanked: 252 times
Hi JayDee
Take a look here....
Choice of:
https://www.adafruit.com/category/88
a variation ?:
From Flowcode:
jay_dee
Post by jay_dee »
so the HT16K33 looks like a good route to investiagte. I see the FC components has been setup for dot matrix style displays. I guess it would need tweaking to suit a standard 7 segment.
I'll have a read of the datasheet and see how lost i get! J.
What might suit as you have many LED displays to control, is the humble CMOS 4026B as it only needs two connections. It is a counter optimised for 7-segment displays. A positive pulse increments the display (0-9) and a high pulse on reset sets it back to zero.
You would need a little routine that would, for example, reset then pulse in the required number. Even a modest uC can do that in an instant.
