SOLVED: STM32F407IG Build Error
Brendan
Has thanked: 64 times
Been thanked: 17 times
Post by Brendan »
I'm committed to a project using the STM32F407IG MCU, though the project wouldn't build to Hex file and I don't think I'm doing anything stupidly obvious (don't quote me on that :lol: ). I haven't encountered such issues before for other/smaller MCUs of the STM32F407... family.
I then stripped out all macros and components and merely stuck a basic loop at the start of a barebones project, but it still doesn't build.
Initialisation parameters in build options are taken directly from CubeMX (without clock issues), leading me to suspect an issue elsewhere.
I provide the basic source project and compiler report for investigation, hoping this is something simple and can be resolved quite soon.
Thanks and regards,
Brendan
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM\batch\stm32comp.bat "BUILD_ERROR_DEBUG_STM32F407IG" "C:\PROJECTS\Futura\Flowcode\" "32F407xx" "F4" "stm32f_ccm64.ld" "16000000" "1024K" "128K" "C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\"
C:\PROJECTS\Futura\Flowcode>REM CRC: 1CECFE3DB3A1BD5169AEA98AD43ADE631EF0A88FFA736FBD84BE44176323F463C8515F4CD0D20BEBDFE06A9E70103FA105C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF532505B4DECBAEAC96954F191918D76F05058F85C62E78168DB2117B7F66DFFAB9D4CD39D9819A47B593E224EEC6BA2B1CF18B22880D87C51B667E8BA6E12E6B26FA06B6F4F108199331CCC4A9A2DADF899B5E4011DBDD5202C3050DA273BE4EEBA213254BC0AD6E15FDF8E24F7A49525E37122B659B22A01CA71203F3D907500295E1D946A835C79
C:\PROJECTS\Flowcode>REM REVISION: 1.0
C:\PROJECTS\Flowcode>REM GUID: E810EE73-4726-4718-B23E-B579C5ADBC40
C:\PROJECTS\Flowcode>REM DATE: 08\08\2022
C:\PROJECTS\Flowcode>REM DIR: FCD\ARM\batch\stm32comp.bat
Project BUILD_ERROR_DEBUG_STM32F407IG
Device STM32F407xx
C:\PROJECTS\Flowcode>arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Os -DSTM32 -DSTM32F4 -DSTM32F407xx -DUSE_HAL_DRIVER -DHSE_VALUE=16000000 -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\CMSIS\Include" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\CMSIS\Device\ST\STM32F4xx\Include" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\STM32F4xx_HAL_Driver\Inc" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\stm32cubeF4\Drivers\STM32F4xx_HAL_Driver\Inc\Legacy" -I"C:\Program Files (x86)\Flowcode\Common\Compilers\starm\\inc" -fmessage-length=0 -fdata-sections -ffunction-sections -w -c "BUILD_ERROR_DEBUG_STM32F407IG.c" -o "BUILD_ERROR_DEBUG_STM32F407IG_STM32F407xx_16000000\BUILD_ERROR_DEBUG_STM32F407IG.o"
BUILD_ERROR_DEBUG_STM32F407IG.c:74:80: error: invalid initializer
MX_GLOBAL MX_UINT32 FCV_GAUGE_MEASVALSRAW_PREV[FCVsz_GAUGE_MEASVALSRAW_PREV] = 0; // Records the previous gauge measurement values for compare to new
Error(s) in build
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ARM\batch\stm32comp.bat reported error code 0x1
Autoclose turned off
FINISHED
BUILD_ERROR_DEBUG_STM32F407IG.fcfx
(14.37 KiB) Downloaded 173 times
Has thanked: 246 times
Been thanked: 258 times
Re: STM32F407IG - Build Error
Hi Brendan
I also get an error
There is a problem with these variables. I have deleted these, then I can compile it
Brendan
Post by Brendan »
Many thanks Stefan!
I'll revisit the vars to see if there's anything obvious with them, and a successful duplication and rebuild of the same barebones project and settings confirm what you say.
I suspect something had a hiccup somewhere along the way (e.g. accepted illegal initialiser, or something like that), and thank you again. Entirely appreciated, and a great relief!
Best regards,
Brendan
Hi Brendan
Any time again.
I think it's just this initial value of the array. Do not use a value
Brendan
Post by Brendan »
Thanks Stefan.
Indeed, your finding is ahead of me, and aware that arrays can only be initialised using (e.g.) syntax { 0,0,0,0 }, I'm not sure where the single '0' came from, or how that got past the gatekeeper if my own fault.
Anyway, thank you again, and lesson learned for future reference :)
Best regards,
Brendan
