Simple Program - Want to get state of some switches.
Billduck1302
Has thanked: 2 times
Post by Billduck1302 »
It does not recognise a Boolean NOT DG. When I fix it, with a space, it reverts to NOTDG, and as such, thinks it is a variable. It sees the same error when I step thru it with F8. I may be asleep at the wheel.
Thanks in advance.
7Segment DisplayV1.fcfx
(34.06 KiB) Downloaded 121 times
Has thanked: 435 times
Been thanked: 651 times
Re: Simple Program - Want to get state of some switches.
Try exclamation mark instead of the word NOT (!) as your operand
Billduck1302
I will add that !(Variable) works but not NOT(Variable)
Has thanked: 713 times
Been thanked: 775 times
If comparing variables, you need to use logical operators and not bitwise operators.
E.g
&& instead of & (or AND)
|| instead of | (or OR)
Note the pipe | is the key next to Z.
! instead of NOT as Chipfryer27 stated
