After update today!
Has thanked: 905 times
Been thanked: 219 times
Flowcode v10 After update today!
Post by jgu1 »
Hi team!
After update today the ST7796 display can´t compile anmore? If I roll back from 10 to 9 it work. :roll:
I have also made a test with the ILI9488 and ILI941, seem to work ok.
Br Jorgen
ST7796_Standard.msg.txt
(9.14 KiB) Downloaded 196 times
ST7796_Standard.fcfx
(46.7 KiB) Downloaded 207 times
Has thanked: 177 times
Been thanked: 1026 times
Re: After update today!
Post by mnfisher »
The error is -Werror=maybe-uninitialized for X and Y in the display 'DrawLine' macro.
This means that for some paths these might be used without being initialised - leading to incorrect results. This may never happen - and they really should be initialised before use rather than relying on them having a certain value (in simulation 0 - but not necessarily on hardware)
You can ignore this (at your own risk !) by adding
target_compile_options(${COMPONENT_LIB} PRIVATE -Wno-maybe-uninitialized)
To CMakeLists.txt in the 'main' subdirectory of the build folder.
Flowcode v10 Re: After update today!
Post by jgu1 »
Hi Martin!
Thank you for your help and advice, as always, appreciated ;)
As I mentioned everything work before update ver.9 there must be a bug as you describes in ver.10
I hope and prefer to see and hope the teams will fix this and push it in update :) at least you have found the bug. If not I will use (dare) to use your suggest.
Br Jorgen
Has thanked: 794 times
Been thanked: 853 times
The only change from v9 to v10 was to make the component icon compatible with dark mode.
For some reason an older version got stored within the repo.
I have now updated the repo with the latest version, so your project should compile again when the component has been updated on the library database.
I will let you know when it has.
Many thanks for bringing this to my attention & apologies for the inconvenience.
Thank you Martin for your excellent support.
The updated ST7796 component is now available for downloading.
Post by jgu1 »
Hi Martin & Martin :P
No apoligies Martin, I know you always "will be there" if challenge. When I see there is is update with these display and ESP32 I always made at test with my testprogram with these display, I have lot of project with this display I still make som update on the project, so if they not work after update, you mm team, will be the first who know if they not working :lol:
Now after last update, (11) it work perfect again.
Thank you to you both.
Br Jorgen
:lol:
That's great!
I'm glad you now can compile again.
Thanks for letting us know.
