PIC16F1779 DAC and PWM problem
Sasi
Has thanked: 43 times
Been thanked: 15 times
Flowcode v10 PIC16F1779 DAC and PWM problem
Post by Sasi »
I would like to use the PIC16F1779 MCU in a new project.
According to the Microchip datasheet, it has 4 10-bit DACs and 4 5-bit DACs.
I want to use the 10-bit DACs, but they only appear as 8-bit DACs in Flowcode.
(Note: The 5-bit DACs all have their outputs routed to the B2 port pin, and I can't change this in the "Properties" window.)
The MCU also has 4 10-bit PWMs and 4 16-bit PWMs that I also want to use, but I can only access 2 8-bit channels in Flowcode at the moment.
Is it possible to fix this so that these Component Macros work with the parameters according to the datasheet?
Sasi
Has thanked: 724 times
Been thanked: 783 times
Re: PIC16F1779 DAC and PWM problem
This needs looking into since the maximum number of DAC's is currently 4 so even if all the pins are correct, only the first 4 will work.
This device has a funny register for CCP as that's what we currently use for PWM.
it goes CCP1, CCP2, CCP7 & CCP8
The way Flowcode address the CCP registers is based on Channel selection within properties.
If Channel three is selected then the 3 is used for register e.g. CCP3CON, CCPR3L etc.
Of course they don't exist so there will be errors on compiling.
I will see if I can sort, this but it won't be today.
Attached a modified fcdx file that will hopefully address the first 4 DACs.
I have not got the hardware, so unable to test.
For the fcdx file:
If you browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
%ProgramData%\MatrixTSL\FlowcodeV10\FCD\PIC\
Replace the original file with the attached version.
If Flowcode is already open, then you will need to reload your project.
If you run any component updates, then the fcdx you added will be overwritten.
16F1779.fcdx
(24.27 KiB) Downloaded 402 times
Sasi
Post by Sasi »
Hi Martin!
Thanks for your answer.
I'm expecting the microcontrollers by the middle of next week, so I can't test the peripherals on hardware yet.
I just tried to see if Flowcode would be a suitable development environment for this MCU.
That's how I found these oddities.
Sasi
Sasi
Post by Sasi »
I forgot to write that I will of course give feedback on the operation of your modifications as soon as the chips arrive.
I replaced the 16F1779.fcdx file and now DAC channels 1, 2, 5, 6 appear as 10-bit in the "Properties" window. :D
Thanks again.
You're welcome.
I have added 4 extra channels to the DAC CAL, so it should allow you to use all 8 channels now.
Can you try the attached with the toolchain that is on Flowcode's download page.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
%ProgramData%\MatrixTSL\FlowcodeV10\CAL\PIC
Place the attached C file.
If you run any library updates, then the PIC_CAL_DAC.c you added will be overwritten, so it will stop working again (unless the PIC_CAL_String.c update has been pushed).
PIC_CAL_DAC.c
(13.99 KiB) Downloaded 401 times
PWM odd naming conventions has now been addressed.
The attached fcdx file when in place should allow you to use all four PWM channels
16F1779.fcdx
(24.2 KiB) Downloaded 411 times
Sasi
Post by Sasi »
Hi Martin,
Thanks for your support.
Unfortunately the MCUs have not arrived yet.
I ordered them from Mouser along with some standard parts and they are still in "Export Review" status. They have not sent any notification about the reasons, they do not respond to emails. I have had good experiences with this parts dealer so far. I hope this is just a temporary problem in their system and the package will arrive in a few days.
Sasi
Sasi
Post by Sasi »
Hi Martin!
I tried the new .fcdx file and I find that the period register value in the Properties window cannot be greater than 255.
Regarding PWM solutions, I remember using the PIC12F1572 MCU PWM peripheral in a project under Flowcode7.
The PIC12F1572 does not have a CCP module, it only has 3 PWM peripherals, the structure of which is almost exactly the same as the one in the PIC16F1779. I tried the PIC12F1572 PWM under Flowcode10. It works with version 9 of PWM.fcpx, you can set the period and the duty cycle statically.
(When I used the "SetDutyCycle10" command in a loop to achieve a variable duty cycle, the duty cycle did not change).
Would it be possible to create a new extended PWM Component Macro based on the 1572, adding the currently unavailable parameters? (Offset, Phase, Modes of operation)
Sasi
Sasi
Post by Sasi »
Hi Martin,
The parts have arrived. :)
I tried the 10-bit ADCs with the modifications you sent. Channels 1 and 2 work, but the output of channels 5 and 6 does not.
(Note: If I select FVR as the reference voltage source, the voltage value cannot be selected in the Properties window.)
I could not get the PWM to work at all.
As I mentioned in the previous post, the value of the periodic register cannot be set higher than 255 in the Properties.
The PIC16F1779 MCU has only 4 CCP peripherals, but currently 8 channels can be selected.
I am attaching the version of the components used:
State of UPDATES.jpg (53.86 KiB) Viewed 6978 times
Sasi
