PIC12f1840 speed selection
alanwms
Has thanked: 26 times
Been thanked: 8 times
Post by alanwms »
Flowcode version 9.
Running a short program at project option speed 32 (mhz). Delay times are double expected time. I changed to project option time to 20 mhz and the delay times are correct.
FYI
Has thanked: 724 times
Been thanked: 783 times
Re: PIC12f1840 speed selection
Hi.
Sounds like you have not set up the internal oscillator correctly.
Take a look at the Wiki.
alanwms
Post by alanwms »
If the system timing is correct at 20mhz, would that not indicate internal oscillator to be correct?
Has thanked: 442 times
Been thanked: 661 times
If you mean where you can select clock speed under project options (highlighted yellow) then that only tells Flowcode what speed you are running at, not the hardware. You still need to select that (highlighted green) and possibly add in a C-code block.
Screenshot 2025-09-10 154934.jpg (103.25 KiB) Viewed 4695 times
If you post your chart we can look further.
alanwms
Post by alanwms »
Thank you. I think I have selected the correct register number for the osc? Maybe not? I have attached my file
PWM CODE.fcfx
(18.46 KiB) Downloaded 277 times
Have a look at the attached snippet from Datasheet. It illustrates the available options you can select using the internal oscillator. If you choose one of them then you should be good. 20MHz would only be an option if using an external crystal.
Flowcode has the Internal Oscillator Helper under Runtime, and this will tell you the code to use in your C-block for your chosen IntOsc, and of course don't forget to set your clock speed to match, under "Other Options" as this tells FC what frequency you are running.
Screenshot 2025-09-11 194148.jpg (61.73 KiB) Viewed 4674 times
