COM Port - Setting Port and Baud within App
jay_dee
Has thanked: 102 times
Been thanked: 74 times
Post by jay_dee »
I have an App Developer program which recieves Serial Data from a PIC, this is working well.
But how can I Refresh COM Port, Change Port and Change Baud Rate from within a deployed/Running App?
I tried to make the properties visible but could not make this work. A Running app wont set focus on the COM Icon
However,
Is there a way to set buttons and Text boxes, calling and setting properties of the Component?
This could be a cleaner method for an end user.
But I get quickly lost with the 'Built-In Function' components :)
Project so far...
RecieveDiagnositicValues_V7.fcsx
(67.49 KiB) Downloaded 337 times
Has thanked: 647 times
Been thanked: 856 times
Re: COM Port - Setting Port and Baud within App
In the source project simply right click any properties you want access to and select Expose to top level.
This basically copies the property as a root property in the project. You can see the root properties by clicking on an empty area of the panel or by selecting the Root component from the drop down menu at the top of the properties window.
You can add categories by right clicking on Properties and selecting New category and then drag the properties around to better organise as needed.
For example here is one of our apps.
Screenshot 2025-10-02 101255.png (20.15 KiB) Viewed 9304 times
jay_dee
Post by jay_dee »
Thanks that woirks a treat. J.
