ESP32 WLAN init and BT init Problem
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
Hello FC team,
if I do a init of ESP32 WLAN and BT component together I´ll get the follwing compiler message.
[5/7] Linking CXX executable esp-project.elf
[6/7] Generating binary image from built executable
esptool.py v3.3.4-dev
Creating esp32 image...
Merged 27 ELF sections
Successfully created esp32 image.
Generated C:/ESP32/YGE_DBU_Texy/YGE_DBU_Texy_V_1_8_3/build/esp-project.bin
[7/7] cmd.exe /C "cd /D C:\ESP32\YGE_DBU_Texy\YGE_DBU_Texy_V_1_8_3\build\esp-idf\esptool_py && C:\ESP-IDF\-tools\python_env\idf4.4_py3.7_env\Scripts\python.exe C:/Users/dirkb/Desktop/esp-idf/components/partition_table/check_sizes.py --offset 0x8000 partition --type app C:/ESP32/YGE_DBU_Texy/YGE_DBU_Texy_V_1_8_3/build/partition_table/partition-table.bin C:/ESP32/YGE_DBU_Texy/YGE_DBU_Texy_V_1_8_3/build/esp-project.bin"
FAILED: esp-idf/esptool_py/CMakeFiles/app_check_size C:/ESP32/YGE_DBU_Texy/YGE_DBU_Texy_V_1_8_3/build/esp-idf/esptool_py/CMakeFiles/app_check_size
Error: app partition is too small for binary esp-project.bin size 0x13c100:
- Part 'factory' 0/0 @ 0x10000 size 0x100000 (overflow 0x3c100)
ninja failed with exit code 1
Running ninja in directory C:\ESP32\YGE_DBU_Texy\YGE_DBU_Texy_V_1_8_3\build
Executing "ninja all"...
Is this a known issue?
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
Has thanked: 174 times
Been thanked: 994 times
Re: ESP32 WLAN init and BT init Problem
Post by mnfisher »
Hi Dirk,
It's complaining that the app partition isn't large enough (though if all you are doing is initialising the WiFi and BT I would be surprised that this is the case)
You will need to define a custom partition table - and point to that using menuconfig - allocating more memory to the application.
Something like
# Name,   Type, SubType, Offset,  Size, Flags
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
nvs,      data, nvs,     0x9000,  0x6000,
phy_init, data, phy,     0xf000,  0x1000,
factory,  app,  factory, 0x10000, 2M
Assuming you are using a 4MB (or above part).
Save as partition.csv (name to suit) and use menuconfig partition table to point to this.
Then recompile - and test again.
Might also be worth setting compiler options to 'size' (again using menuconfig)
dvcam99
Post by dvcam99 »
Hello Martin,
many thanks for your suggestion. I will review it.
Additional question. Were do I find the menuconfig partition table in order to setup the link for the csv?
In between I did a cross check. Only BT init or WLAN init compiles correctly. Both together not like mention before.
The reason why I´m looking forward in order to use BT and WLAN is actually I want to make sure both are switched off. This because I want to save power and more important reducing the risk of 2.4GHZ interfernece by the ESP32. May the concern is that a beacon or so would start.
BR
Dirk
Has thanked: 245 times
Been thanked: 256 times
Hi Dirk
something else for power....
If you like to save power you can also reduce the speed from the clock in the menue config or with a c-command to 160Mhz or 80Mhz
and you can let the esp32 sleep for a while or sleep until you wake the esp32 up with a pin pull down
viewtopic.php?t=3130&hilit=power
Has thanked: 629 times
Been thanked: 836 times
This is something I've personally come across and I ended up having to manually edit a file in the compiler.
Here's the error I was getting: ESP32 Image length 1352272 doesn't fit in partition length
Edit this file in a text editor.
C:\FC_ESP\frameworks\esp-idf-v5.3.1\components\partition_table\partitions_singleapp.csv
For me the fix was to Increase the "factory, app" size from 1M to 0x180000.
dvcam99
Post by dvcam99 »
Hello Stefan,
Hello Ben,
I can report that the fix from Ben is working. I can compile now with WLAN and BT init together.
This for the main reason that I can not tolerate a 2.4GHZ emission from the ESP32. LOL
I will see if I can monitor a difference in the emission spectrum with or without BL WLAN init.
So far many thanks guys.
BR
Dirk
Post by mnfisher »
Can do as Ben suggested - or from menuconfig:
I'd used the custom 'route' for creating a SPIFFS partition...
Then select the top row Partition table (single factory app, no OTA) ----> and change to Custom...
Then change the name here if needed:
Ooh that's also good to know thanks Martin.
