Measure the supply voltage of an AVR
pantelispv5
Post by pantelispv5 »
Hi, There. I need to measure the voltage that supplies the AVR 8bit ATtiny series using this very same MCU. Maybe I can use the Vgap reference 1.1V But I would like to ask if this can be done directly in Flowcode 11?
Has thanked: 312 times
Been thanked: 479 times
Re: Measure the supply voltage of an AVR
It should be easy to measure the Vcc within Flowcode using an analogue input and the voltage reference. A web search brought up this article and this article which might be of help.
Has thanked: 478 times
Been thanked: 713 times
Following on from above, I think Steve001 posted a solution in the old forum. A search there would probably be worth trying.
pantelispv5
chipfryer27 wrote: ↑
Tue Dec 16, 2025 10:23 am
My question was only how to calculate in flowcode (if this is possible without C code) the difference voltage VDD-Vbg. Thanks
Has thanked: 649 times
Been thanked: 856 times
If you have a spare ADC pin then the easy way is to connect the ADC pin to something like this.
Screenshot 2025-12-22 114355.png (10.59 KiB) Viewed 2888 times
The diode will have a specific forward voltage drop across it, usually around 0.7V for a standard diode and more like 0.45V for a schottky. As your VCC drops the ADC reading will rise allowing you to calculate the value of VCC.
Assuming a 10-bit ADC and a 0.7V diode. ADC resolution is ((1 << 10) - 1) = 1023
VCC Voltage = (0.7 / FLOAT ADC Reading) * 1023.0
A fixed voltage reference would be better then a diode but in a pinch a diode will work.
Note there is some variation of the forward voltage drop across a diode with temperature, hence why the diode isn't ideal. The resistor value doesn't really matter just keep it over 10K to reduce current usage.
If your device has an internal reference then it may be fairly simple to use this instead to do the same thing.
