Esp32 Timer Problem
Oscar_T
Has thanked: 37 times
Been thanked: 10 times
Esp32 Timer Problem
Post by Oscar_T »
I can't compile the program. I found that if I remove the timer component the program compiles.
Kind regards
Flowcode1.fcfx
(17.43 KiB) Downloaded 821 times
Has thanked: 96 times
Been thanked: 291 times
Re: Esp32 Timer Problem
Looks like the Timer component is not yet compatible with ESP.
Can I suggest that you use a Timer Interrupt instead.
That can then call a macro/function that increments global variables to give you your timed events.
Oscar_T
Post by Oscar_T »
Hi Leigh
Yes, now it's working!
Can you explain the timer period parameter (256 and 1000) what it refers to?
Now I have set 256 and seconds
Kind regards
Glad you have it working :D
It's a generic drop box, but you can enter any value for the time period (time between interrupts), as you have found.
Oscar_T
Post by Oscar_T »
Thanks Leigh
Now i've another question
I am trying to use the esp32 module to create a small test station. I need to generate a sine wave and I succeeded.
the problem is that the output is not stable and therefore every few seconds I find a glitch on the sinus. I tried to generate the wave in different ways but even putting it in the main loop I always have the same problem.
It almost seems that the output of the dac stops ...
I think the problem here could be that ESP runs an RTOS.
That's not ideal for signal generation due to task scheduling.
I think that DMA might be possible, but I've not tried it.
Oscar_T
Post by Oscar_T »
Do you think we can test for DMA channels?
Has thanked: 590 times
Been thanked: 778 times
What are you using the output the sine wave, is it the internal DAC or PWM or is it via an external comms device?
Oscar_T
Post by Oscar_T »
Internal Dac!
Kind regards
Oscar_T
Post by Oscar_T »
I have a strange problem with esp32 boards.
It looks like they are programmed but fail to boot ...
I have 3 boards (1 wroom-32 and 2 wroom-32d) and all three are doing the same joke
The version is esp32_devkitc_v4, clicking the two physical buttons nothing happens.
