how to connect to different node's trough tcp ip
ruben123
Has thanked: 6 times
Been thanked: 3 times
Post by ruben123 »
HI ,
I'm trying to control my power supply's trough tcp/ip I worked it out to control 1 power supply .That program works great . but when I'm trying to connected the other one it all goes wrong .
what i tryed so far:
-every powersuply has it's unique ip adress and its on port .
-do i have to close the port every time i connect to another power supply?
I'm totally new in al the internet things
thanks in advantage for your help guys .
power_suply_V_A_P_with_feedback_minderbelasting_TCPIP_keymapping_test_belasting1V2.fcsx
2power supply's
(58.35 KiB) Downloaded 820 times
Has thanked: 647 times
Been thanked: 856 times
Re: how to connect to different node's trough tcp ip
Thanks for posting that looks great. Have you tried using a second network comms component to establish the communications with the second device?
ruben123
Post by ruben123 »
Hello BenR
I used another tcp_Ip component but no connection with the load at al . I think this would work if i had multiple network cards in my PC but unfortunately I don't have .
power_suply_V_A_P_with_feedback_minderbelasting_TCPIP_keymapping_seconde_tcpIP.fcsx
(54.9 KiB) Downloaded 825 times
ruben123
Post by ruben123 »
hi all
I finaly figuered 8-) it out how to connect to different node's trough tcp/ip and make it look "realtime" i start from scratch again .
now every node has +/- 750ms to speak to the main PC that controls everything .
A question to the developers : when i use the timer interupt the given info about the frequentie isn't right ? i had to go on my feeling wich frequentie works for me becaus the highlighte frequentie doesn't match the real frequentie.
realtime_strategieV1.2.fcsx
why doesn't match the freq given the "real" frequentie"
(35.24 KiB) Downloaded 732 times
Yes we are aware the simulated timer interrupt rate may be a bit off and one of our major goals for the next version is to try and improve this.
Well done on getting it working though and many thanks for sharing with us.
ruben123
Post by ruben123 »
hi everybody
I encountered next probleme when running the flowchart in simulation my 2ddashboard ended up beining white
the only thing i can do then is close everything en start everything up again
thx again for your help guys
Greetings Ruben
simulator_V1.4.1_realtime_strategie_tcp_Ip_oké_output_Input_oké_update.fcsx
(63.79 KiB) Downloaded 757 times
Has thanked: 311 times
Been thanked: 479 times
Hi.
I've tried simulating your program, but I've not been able to replicate the problem. Were you doing something particular when the error occurred or was there any error message reported?
