Incorporating images from Webserver(Generic/Flash) component
ssttrragmail
Has thanked: 18 times
Been thanked: 2 times
Post by ssttrragmail »
Where can I create a folder to put all the images to be correctly incorporated by the WebServer´s component pages ?
Has thanked: 616 times
Been thanked: 814 times
Re: Incorporating images from Webserver(Generic/Flash) component
If you're using the example from here.
https://www.flowcode.co.uk/wiki/index.p ... amic_Files
Then the .htm files and image files live in the same Files folder which should be in the same directory as the Flowcode project file.
ssttrragmail
Thanks for the return !.
Specifically, I´m trying to load a simple icon "FC8.bmp" image in the "index.htm", as part of an ESP32 WebServer page.
I´ve understood that the "images" and the "fcfx" files must be in the same directory. Is this correct ?
But it seems that didn´t work in this case - the image does not load after the simulation starts and the page loads.
Could someone give some clue to overcome this fact ?
fig 1.jpg (58.58 KiB) Viewed 4247 times
fig 2.jpg (20.11 KiB) Viewed 4247 times
fig 3.jpg (55.58 KiB) Viewed 4247 times
The embedded html source type cannot display external inage resources. You can only use images with the dynamic file type webserver setting. The example in the wiki I linked to should show you how it works.
Let us know how your getting on.
ssttrragmail
I will. I "neeleety" (need little time) on it.
Thanks.
