ESP wroom 32 wifi
bdjbuster
ESP wroom 32 wifi
Post by bdjbuster »
can anyone help me to create an Access point with an Esp 32. i tried something but i can't get it done. does anyone have an example?
Berend
test32.fcfx
(9.89 KiB) Downloaded 815 times
Has thanked: 107 times
Been thanked: 302 times
Re: ESP wroom 32 wifi
I thought we had this working, but looks like we might have some problem.
Sorry, due to holidays, looks like this will need some time to check over and fix in the new year.
bdjbuster
Post by bdjbuster »
Hello, thank you for your comment. do you comment when the problem is resolved? happy Holidays!
I've now fixed this and should be available on the update system soon
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
I tried to open a acess point too
If I set the Encryption to ZERO the acces point will be opened at the ESP32.
Ican sent a pint to the ESP32 too.
Is there maybe a tutorial to learn mor about setting up the WLAN correctly and installing/creating a web page inside the ESP32??
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
bdjbuster
Post by bdjbuster »
Thanks for the update, I can now indeed create an access point. but I would also see an example of what you can do with an access point.
dvcam99
Post by dvcam99 »
Yes a tutorial or short FC programm showing the ESP32 access point with a smal html web page would be fantastic.
BR
Dirk
Has thanked: 633 times
Been thanked: 837 times
Hello Dirk,
Hopefully this video shows you how it's done.
https://youtu.be/DaViZAhSxuQ
dvcam99
Post by dvcam99 »
Hello Ben,
many thanks!! Very good video that is brillant and a good starting point.
In between I have the ESP32 running as a access point too.
Like I asked in my other post, is there a mximum limit of 5 dynamic strings to put in the internal Webserver component?
BR
Dirk
