大家好, 這是我第一次在論壇上發帖。希望你能幫到我。
我從youtube上看到了這段視頻, 關於如何使用ESP32與 Mqtt 協定的視頻 (https://www.youtube.com/watch?v=efDrZdLGeTY), 我試圖寫相同的代碼, 但它不工作。
問題1: . fcfx 和 .fcsx 無法像視頻一樣連接。
問題 2 : AppDev. fcsx 將在 5 秒後自動停止運行。
我用 Rpi4b 是我的 Mqtt 經紀人 (https://www.flowcode.co.uk/wiki/index.p ... QTT_Broker)
Picture_2是我的 Rpi 設置。(MQTT 經紀商測試和 IP 位址)
MQTT_ESP32_AppDev did not work.
kevin22630582
- Has thanked: 2 times
- Picture_2.png (429.76 KiB) Viewed 6357 times
- MQTT_ESP32_AppDev.fcsx
- (14.09 KiB) Downloaded 590 times
- (view online)
- MQTT_ESP32.fcfx
- (13.21 KiB) Downloaded 518 times
- (view online)
- Has thanked: 310 times
- Been thanked: 475 times
Re: MQTT_ESP32_AppDev did not work.
For convenience, here's a translation of the original post into English:
Hi everyone, this is my first time posting on the forum. Hope you can help me.
I saw this video from youtube, about how to use ESP32 and Mqtt protocol video ( https://www.youtube.com/watch?v=efDrZdLGeTY), I tried to write the same code, but it doesn't work.
Question 1: .fcfx and .fcsx cannot be connected like video.
Question 2: AppDev. fcsx will automatically stop running after 5 seconds.
I use Rpi4b as my Mqtt broker ( https://www.flowcode.co.uk/wiki/index.p ... QTT_Broker)
Picture_2 is my Rpi setting. (MQTT broker test and IP address)
- Has thanked: 792 times
- Been thanked: 850 times
Welcome to the Flowocde forums.
If It was me,
The first thing I would do is check that both the ESP32 and RPI can be seen on the network.
I would use a network utility tool.
Then I would check that RPI IP matches up with the stated IP within IOT Made Easy component.
As you have set up a broker name and password, within IOT Made Easy (Pi,a0953530662), have you set up the same name and password within the RPI?
If It was me,
- Has thanked: 110 times
- Been thanked: 302 times
Also...
If you stop the mosquitto server as a service, then run with the command
you will get on screen messages that will help,
such as when the client connects etc..
mosquitto -vsuch as when the client connects etc..
kevin22630582
Thanks Steve-Matrix for the translation.
Reply to medelec35 :
First, thank you for your reply. I followed your suggestion, check my hardware.
(1) Rpi and ESP32 both can be seen on the network. (2) Rpi IP address matches up with the stated IP within IoT Made Easy component. (3) I found I didn't set up the broker name and password, so I changed the component properties.
kevin22630582
Thanks you for you reply!LeighM wrote: ↑Tue Nov 16, 2021 3:32 pmAlso...
If you stop the mosquitto server as a service, then run with the commandyou will get on screen messages that will help,Code: Select all
mosquitto -v
This was the screen message, is it got some wrong ?
- Has thanked: 645 times
- Been thanked: 854 times
Mosquitto version 2.0 and after requires a bit of additional configuration to enable remote access.
The clue is the "starting in local only mode"
The details are available here.
https://mosquitto.org/documentation/aut ... n-methods/
Fingers crossed
Fingers crossed
