variables flowcode9
d820513
Has thanked: 2 times
variables flowcode9
Post by d820513 »
Why can't the flowcode 9 variables be visible in the proteus ???
OlegKRS
Been thanked: 3 times
Re: variables flowcode9
Post by OlegKRS »
To see the variables in proteus * .elf file you need in the file avra.bat instead of the key "-Os", register the key "-g". It should turn out like this:
"%~dp0..\bin\avr-gcc.exe" -mmcu=%1 -g -ffunction-sections -fdata-sections -funsigned-char -o %2 %3 -lm -Wl,-gc-sections.
In this case , the compiler will create a file .elf without optimization and proteus will be able to see the variables.
File avra.bat is located in the folder: "C:\Program Files (x86)\Flowcode\Common\Compilers\avrv5\batchfiles".
d820513
Post by d820513 »
thanks, it worked
d820513
Post by d820513 »
Oleg, thank you, could you tell me how I can send text to uart through the flowcode console?
I can not find it
OlegKRS
Post by OlegKRS »
Sorry, but I do not know how send text to uart through the flowcode console.
Has thanked: 650 times
Been thanked: 856 times
Ive created a new component that should simplfy this for you.
To get the new component simply go to the Help -> Library updates and then change files in use to full database.
Here is an example using the new component.
ConsoleDemo.fcfx
(8.35 KiB) Downloaded 592 times
Then simple type your data to transmit into the User Data console.
