API Panel.Position.Camera.GetEye
Gets a handle to the eye camera position
This function has no parameters
Returns the handle to the eye camera position
This gets the position of the eye of the camera - this is the point the camera appears to be looking from. The camera is always the first view of the System Panel. No other camera position can be manipulated with this API.
The cameras eye is always orientated looking towards the target in Z along a ray perpendicular to the target plane (also known as the object plane).
The coordinates and rotation are variable depending on the position of the camera, but the scale is unused and set to (1,1,1) for the resultant position. This position is compatible with any of the Position API calls.
- Add to a calculation icon:
result = ::Panel.Position.Camera.GetEye()
