API Panel.Position.Camera.GetEye
<sidebar>API Contents</sidebar> Gets a handle to the eye camera position
Class hierarchy
Panel
Position
Camera
GetEye
This function has no parameters
HANDLE
Returns the handle to the eye camera position
This gets the position of the eye of the camera - this is the point the camera appears to be looking from. The camera is always the first view of the System Panel. No other camera position can be manipulated with this API.
The cameras eye is always orientated looking towards the target in Z along a ray perpendicular to the target plane (also known as the object plane).
Parts of the camera
The coordinates and rotation are variable depending on the position of the camera, but the scale is unused and set to (1,1,1) for the resultant position. This position is compatible with any of the Position API calls.
  • Add to a calculation icon:
    result = ::Panel.Position.Camera.GetEye()
