Icon Properties
Revision as of 15:23, 5 June 2026 by SteveT (talk | contribs)
The properties of a command icon defines how it behaves when compiled/assembled and when simulated in Flowcode. As each icon has different properties that the user can edit: see the topic on the particular icon of interest.
To edit an icon's properties, either select the icon and the select the 'Properties' option from the 'Edit' menu (Edit > Properties) or simply double click on the icon in the macro view. The icon's properties can also be displayed by right clicking on the icon to display a context menu and then selecting properties from that menu.
Old Versions
This page is current for Flowcode v11 and later. Earlier versions can be found below:
Flowcode v10
Flowcode v9
Flowcode v8
Flowchart icons
Flowchart icons are the commands used in most programming paradigms of Flowcode, i.e. Flowcharts, Code, Blocks and Pseudocode.
Click this link for more information on Editing Icon Properties.
For information on specific icons then see the links below:
IconInput.png Input Icon Properties
IconOutput.png Output Icon Properties
IconDelay.png Delay Icon Properties
IconDecision.png Decision Icon Properties
IconSwitch.png Switch Icon Properties
IconLabel.png Label Icon Properties
IconJump.png Jump Icon Properties
IconLoop.png Loop Icon Properties
IconUserMacro.png Macro Icon Properties
IconComponentMacro.png Component Macro Icon Properties
IconBuiltinFunction.png Simulation Macro Icon Properties
IconInterrupt.png Interrupt Icon Properties
IconCalculation.png Calculation Icon Properties
IconCode.png Code Icon Properties
IconComment.png Comment Icon Properties
IconGroup.png Group Icon Properties
State Diagram icons
A different set of command icons are used for Flowcode's State Diagram programming paradigm.
IconState.png State_Icon_Properties
IconExitState.png Exit_State_Icon_Properties
IconTransitionStraight.png IconTransitionCurved.png Transition_Icon_Properties
IconStateComment.png Comment Icon Properties
