API Panel.Position.RotateTo
Revision as of 22:09, 15 June 2013 by JonnyW (talk | contribs)
<sidebar>API contents</sidebar> Rotates the object to the given rotation
Class hierarchy
Panel
Position
RotateTo
HANDLE Handle
HANDLE Pivot
The coordinates of the rotation center, Handle if zero
HANDLE Axis
An axis to align the angles to, Handle if zero
FLOAT X_Pitch
The absolute local X degrees to update with
FLOAT Y_Yaw
The absolute local Y degrees to update with
FLOAT Z_Roll
The absolute local Z degrees to update with
This rotates an object to the exact orientation specified. The orientation is represented as Euler angles. This is typically useful for setting to an exact angle, but is not recommended for incremental changes - Euler angles suffer from gimbal lock and it can be difficult to maintain an absolute values through incremental changes.
For an incremental change, use RotateAlong.
If Pivot or Axis are zero, world-space is assumed. It is advised not to use world-space in a component that is exported, use this as the coordinate space instead.
Note that a common mistake is to set the orientation to (0, 0, 0) to reset the Handle back to its original position. Where as this will work for objects that are originally aligned to the specified axis, this will not work for objects whose initial position is off axis. To reliably restore the orientation of an object, the original position should be read and stored with a call to Get and the orientation restored using SetRotation.
Note another common mistake is to set the angle relative to the object being rotated. Specifying the same Axis as Handle will cause the object to be rotated relative to itself, which may have unexpected results.
  • Add to a calculation icon:
    ::Panel.Position.RotateTo(handle, pivot, axis, x_pitch, y_yaw, z_roll)
