API Panel.Position.Camera.GetTarget
Gets a handle to the target camera position
This function has no parameters
Returns the handle to the target camera position
This gets the position of the target of the camera - this is the point the camera appears to be looking at, and the point that the camera eye will rotate around in normal operation. The camera is always that of the first view of the System Panel. No other camera position can be manipulated with this API.
The cameras target is always orientated looking away from the eye in Z along a ray perpendicular to the target plane (also known as the object plane). This is the same orientation in the position returned by GetEye.
The coordinates and rotation are variable depending on the position of the camera, but the scale is unused and set to (1,1,1) for the resultant position. This position is compatible with any of the Position API calls.
- Add to a calculation icon:
result = ::Panel.Position.Camera.GetTarget()
