Greetings
in FC9 App developer / "ModbusSlaveSCADA" component / GetLastIncomming() macro,
i think there should be an INPUT field to enter parameter ( like index 0 / index 1 / index 2 / index 4 )
or am i missing something !!
- S_V
FC9 App Developer ModbusSlaveSCADA GetLastIncomming
- Has thanked: 17 times
- Been thanked: 1 time
- FC9_ModbusSlaveSCADA_GetLastIncomming.jpg (71.95 KiB) Viewed 4540 times
S_V
Re: FC9 App Developer ModbusSlaveSCADA GetLastIncomming
Greeting Ben
I think you had addressed a similar one here in FC8
https://www.matrixtsl.com/mmforums/view ... 25#p101325
S_V
S_V
S_V
- Has thanked: 516 times
- Been thanked: 474 times
Hi S_V.
I have added the parameter to the component for FC9
The component won't be pushed onto the update system until next week.
If would you like to test before then, Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
Replace the existing files with the attached file.
If you run any component updates, then the components you added will be overwritten.
Can you let me know if it works for you, please?
C:\ProgramData\MatrixTSL\FlowcodeV9\Components
- ModbusSlaveSCADA.fcpx
- (79.78 KiB) Downloaded 252 times
Thank you so much for the prompt response and the Update.
It is working very well. (I have tested all the functions. in both read/ write).
Thanks you for the Very detailed procedure...Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
S_V
