Greetings
in FC9 App developer / "ModbusSlaveSCADA" component / GetLastIncomming() macro,
i think there should be an INPUT field to enter parameter ( like index 0 / index 1 / index 2 / index 4 )
or am i missing something !!
- S_V
FC9 App Developer ModbusSlaveSCADA GetLastIncomming
S_VE
- Has thanked: 56 times
- Been thanked: 4 times
- FC9_ModbusSlaveSCADA_GetLastIncomming.jpg (71.95 KiB) Viewed 12202 times
S_V
Re: FC9 App Developer ModbusSlaveSCADA GetLastIncomming
Greeting Ben
I think you had addressed a similar one here in FC8
https://www.flowcode.co.uk/mmforums/view ... 25#p101325
S_V
S_V
S_V
- Has thanked: 724 times
- Been thanked: 783 times
Hi S_V.
I have added the parameter to the component for FC9
The component won't be pushed onto the update system until next week.
If would you like to test before then, Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
Replace the existing files with the attached file.
If you run any component updates, then the components you added will be overwritten.
Can you let me know if it works for you, please?
C:\ProgramData\MatrixTSL\FlowcodeV9\ComponentsIf Flowcode is already open, then you will need to reload your project for the new components to work
- ModbusSlaveSCADA.fcpx
- (79.78 KiB) Downloaded 846 times
Thank you so much for the prompt response and the Update.
It is working very well. (I have tested all the functions. in both read/ write).
Thanks you for the Very detailed procedure...Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
S_V
