FC9 App Developer ModbusSlaveSCADA GetLastIncomming
S_VE
Has thanked: 56 times
Been thanked: 4 times
Flowcode v9 FC9 App Developer ModbusSlaveSCADA GetLastIncomming
Post by S_VE »
Greetings
in FC9 App developer / "ModbusSlaveSCADA" component / GetLastIncomming() macro,
i think there should be an INPUT field to enter parameter ( like index 0 / index 1 / index 2 / index 4 )
or am i missing something !!
- S_V
S_V
S_VE
Re: FC9 App Developer ModbusSlaveSCADA GetLastIncomming
Post by S_VE »
Greeting Ben
I think you had addressed a similar one here in FC8
https://www.flowcode.co.uk/mmforums/view ... 25#p101325
S_V
S_V
Has thanked: 724 times
Been thanked: 783 times
Hi S_V.
I have added the parameter to the component for FC9
The component won't be pushed onto the update system until next week.
If would you like to test before then, Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV9\Components
Replace the existing files with the attached file.
If you run any component updates, then the components you added will be overwritten.
Can you let me know if it works for you, please?
ModbusSlaveSCADA.fcpx
(79.78 KiB) Downloaded 846 times
S_VE
Post by S_VE »
Hi Martin,
Thank you so much for the prompt response and the Update.
It is working very well. (I have tested all the functions. in both read/ write).
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
Thanks you for the Very detailed procedure...
S_V
Hi S_V.
Thats great!
I'm glad it's working.
Thank you for the update.
