atmega 2560 flowcode9 does not work
d820513
Has thanked: 2 times
Been thanked: 1 time
Re: atmega 2560 flowcode9 does not work
Post by d820513 »
2
d820513
Post by d820513 »
2
Has thanked: 635 times
Been thanked: 842 times
You might need to click the write config now button if you're not using an Arduino Mega which comes with the bootloader and config pre-written. Hopefully that will solve things for you.
The Write config on download really only applies to PIC devices.
d820513
Post by d820513 »
I am using arduino mega 2560 board.
microchip studio everything works correctly
Has thanked: 772 times
Been thanked: 833 times
As you are using the Arduino Mega 2560 board, just select Build>Project options.
Right-click on any target and select search.
Enter mega 2560 for the search term.
Alternatively, you can just select the Mega250 from the Arduino range of devices:
Arduino Range.png (14.55 KiB) Viewed 6995 times
There will be no need to change the configuration settings as everything is preset.
Flowcode will program the Arduino board directly via USB lead.
No external programmer is required.
You stated at the start of your post:
d820513 wrote:
Sun Feb 26, 2023 4:20 pm
today switched to atmega 2560
People will assume that you are using a discrete microcontroller rather than an Arduino Mega 2560 board, which is why you are facing issues.
d820513
Post by d820513 »
well, why blink works through microchip studio, but FC9 does not work ???
d820513
Flowcode v9 Re: atmega 2560 flowcode9 does not work
Post by d820513 »
martin i did everything you said, but the board still doesn't work. now again checked through microchip studio everything is working correctly
Have you overridden the bootloader by using microchip studio?
If you have you will need to reinstall the bootloader.
Arduinos are designed to be programmed via USB and not via microchip studio.
d820513
Post by d820513 »
this one through the isp port I upload the firmware hex file
If I was you I would restore the bootloader and then only program via the USB connector and not via ISP.
This might help?
