Invert outs in standart components
user2006
- Has thanked: 1 time
I am reprogramming finished device, so i can not change scheme, to control led display i use component from library Displays: 7segment(single) he use low and high for in and out. But me need both low for in and out
- ezgif-5-df84041133.png (19.52 KiB) Viewed 8753 times
- ezgif-5-c9da3ba5d1.gif (1.78 MiB) Viewed 8753 times
Re: Invert outs in standart components
- clock.fcfx
- (22.3 KiB) Downloaded 771 times
- (view online)
- Has thanked: 795 times
- Been thanked: 858 times
Sorry, we can't help you on these forums as they are for Flowcode v9 and v10 only.
You will need to post on these forums.
Have you thought about upgrading to version 10 as all the components are now free.
There are some free devices as well!
You can download v10 from here
Medelec however thx a lot =D I found your solution there with swich off common pin and adding Output pin control =D
Now all work, thanks a lot again =D
- ezgif-5-3aea2ad1fc.gif (910.35 KiB) Viewed 8718 times
