Invert outs in standart components
user2006
Has thanked: 1 time
Post by user2006 »
I am reprogramming finished device, so i can not change scheme, to control led display i use component from library Displays: 7segment(single) he use low and high for in and out. But me need both low for in and out :)
Has thanked: 795 times
Been thanked: 858 times
Re: Invert outs in standart components
Can you attach your project.
Selecting common low and common anode should work as the segments will be low to enable.
user2006
Has thanked: 1 time
Post by user2006 »
medelec35 wrote: ↑
Mon Nov 06, 2023 8:27 am
Hello =)
clock.fcfx
(22.3 KiB) Downloaded 771 times
What version of Flowcode are you using?
user2006
Has thanked: 1 time
Post by user2006 »
8
Sorry, we can't help you on these forums as they are for Flowcode v9 and v10 only.
You will need to post on these forums.
Have you thought about upgrading to version 10 as all the components are now free.
There are some free devices as well!
You can download v10 from here
user2006
Has thanked: 1 time
Post by user2006 »
medelec35 wrote: ↑
Mon Nov 06, 2023 9:53 am
Medelec however thx a lot =D I found your solution there with swich off common pin and adding Output pin control =D
Now all work, thanks a lot again =D
