Hi Team,
Not sure if this is a bug or on my side alone. excuse me if so.
Im new in the ESP boards and purchased the ESP_WROOM_32 as start. I programmed an simple test blink led (on board) and this works. so to me all packages, drivers toolchain datacords cristal freq etc works.
When i only already add the CANBUS component and initialize it the upload fails due a .h file he cant find ?
i tried internal and external MCP2515 and results are different but still stops compiling.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_CAN.c from the text below does exist in my pc. it looks like it cannot find the can.h file to include?
The fail allready occurs without the unit connected to the USB so it should be easy to recreate. hope its simple...
Compiler message, i left top text off...
[1/9] Performing build step for 'bootloader'
[1/1] cmd.exe /C "cd /D C:\FC_ESP\mtxesp32s_sdkconfig\build\bootloader\esp-idf\esptool_py && C:\FC_ESP\esp-tools\python_env\idf5.3_py3.11_env\Scripts\python.exe C:/FC_ESP/frameworks/esp-idf-v5.3.1/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 C:/FC_ESP/mtxesp32s_sdkconfig/build/bootloader/bootloader.bin"
Bootloader binary size 0x6880 bytes. 0x780 bytes (7%) free.
[2/7] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
ccache C:\FC_ESP\esp-tools\tools\xtensa-esp-elf\esp-13.2.0_20240530\xtensa-esp-elf\bin\xtensa-esp32-elf-gcc.exe -DESP_PLATFORM -DIDF_VER=\"HEAD-HASH-NOTFOUND\" -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -DUNITY_INCLUDE_CONFIG_H -D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -D_POSIX_READER_WRITER_LOCKS -IC:/FC_ESP/mtxesp32s_sdkconfig/build/config -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/newlib/platform_include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/freertos/config/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/freertos/config/include/freertos -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/freertos/config/xtensa/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/freertos/FreeRTOS-Kernel/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/freertos/esp_additions/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hw_support/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hw_support/include/soc -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hw_support/include/soc/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hw_support/dma/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hw_support/ldo/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hw_support/port/esp32/. -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hw_support/port/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/heap/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/log/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/soc/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/soc/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/soc/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/hal/platform_port/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/hal/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/hal/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_rom/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_rom/include/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_rom/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_common/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_system/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_system/port/soc -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_system/port/include/private -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/xtensa/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/xtensa/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/xtensa/deprecated_include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/include/apps -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/include/apps/sntp -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/lwip/src/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/port/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/port/freertos/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/port/esp32xx/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/port/esp32xx/include/arch -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/lwip/port/esp32xx/include/sys -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_gpio/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_pm/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mbedtls/port/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mbedtls/mbedtls/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mbedtls/mbedtls/library -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mbedtls/esp_crt_bundle/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mbedtls/mbedtls/3rdparty/everest/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mbedtls/mbedtls/3rdparty/p256-m -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mbedtls/mbedtls/3rdparty/p256-m/p256-m -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_app_format/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_bootloader_format/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/app_update/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bootloader_support/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bootloader_support/bootloader_flash/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_partition/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/efuse/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/efuse/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_mm/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/spi_flash/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/pthread/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_timer/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_gptimer/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_ringbuf/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_uart/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/vfs/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/app_trace/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_event/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/nvs_flash/
include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_pcnt/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_spi/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_mcpwm/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_ana_cmpr/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_i2s/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/sdmmc/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_sdmmc/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_sdspi/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_sdio/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_dac/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_rmt/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_tsens/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_sdm/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_i2c/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_ledc/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_parlio/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_usb_serial_jtag/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/driver/deprecated -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/driver/i2c/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/driver/touch_sensor/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/driver/twai/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/driver/touch_sensor/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_phy/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_phy/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_vfs_console/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_netif/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/wpa_supplicant/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/wpa_supplicant/port/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/wpa_supplicant/esp_supplicant/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_coex/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_wifi/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_wifi/wifi_apps/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_wifi/wifi_apps/nan_app/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_wifi/include/local -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/include/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/common/osi/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/common/api/include/api -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/common/btc/profile/esp/blufi/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/common/btc/profile/esp/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/common/hci_log/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/host/bluedroid/api/include/api -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/bt/porting/ext/tinycrypt/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/unity/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/unity/unity/src -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/cmock/CMock/src -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/console -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/http_parser -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp-tls -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp-tls/esp-tls-crypto -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_adc/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_adc/interface -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_adc/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_adc/deprecated/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_isp/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_cam/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_cam/interface -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_jpeg/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_driver_ppa/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_eth/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_gdbstub/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_hid/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/tcp_transport/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_http_client/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_http_server/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_https_ota/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_https_server/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_psram/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_lcd/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_lcd/interface -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/protobuf-c/protobuf-c -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/protocomm/include/common -IC:/F
C_ESP/frameworks/esp-idf-v5.3.1/components/protocomm/include/security -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/protocomm/include/transports -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/protocomm/include/crypto/srp6a -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/protocomm/proto-c -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/esp_local_ctrl/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/espcoredump/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/espcoredump/include/port/xtensa -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/wear_levelling/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/fatfs/diskio -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/fatfs/src -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/fatfs/vfs -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/idf_test/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/idf_test/include/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/ieee802154/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/json/cJSON -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/mqtt/esp-mqtt/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/nvs_sec_provider/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/perfmon/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/spiffs/include -IC:/FC_ESP/frameworks/esp-idf-v5.3.1/components/wifi_provisioning/include -mlongcalls -Wno-frame-address -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-stpcpy -fno-builtin-strncpy -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fno-shrink-wrap -fmacro-prefix-map=C:/FC_ESP/mtxesp32s_sdkconfig=. -fmacro-prefix-map=C:/FC_ESP/frameworks/esp-idf-v5.3.1=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-declaration -Wno-cpp -Wno-unused-function -Wno-unused-variable -Wno-unused-but-set-variable -Wno-incompatible-pointer-types -Wno-discarded-qualifiers -Wno-int-conversion -Wno-pointer-sign -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj -MF esp-idf\main\CMakeFiles\__idf_main.dir\esp-project.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj -c C:/FC_ESP/mtxesp32s_sdkconfig/main/esp-project.c
In file included from C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\includes.c:291,
from C:/FC_ESP/mtxesp32s_sdkconfig/main/esp-project.c:240:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_CAN.c:150:10: fatal error: driver/can.h: No such file or directory
150 | #include "driver/can.h"
compilation terminated.
ninja failed with exit code 1
Running ninja in directory C:\FC_ESP\mtxesp32s_sdkconfig\build
Executing "ninja all"...
Build Failed.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code 0x1
Autoclose turned off
FINISHED
ESP CANbus not compiling
Dutch
- Has thanked: 3 times
- Been thanked: 2 times
- Has thanked: 635 times
- Been thanked: 842 times
Re: ESP CANbus not compiling
Thanks for letting us know, could be something related to the version of the IDF ESP compiler. We will investigate and see if there is an easy fix.
celebriums
- Has thanked: 25 times
- Been thanked: 13 times
Dear Dutch,
I am downloading your file and running a test. I currently have ESP-IDF 5.5 installed.
I will share the results with you.
Sadık Süme
celebriums
Dear Dutch ve Dear Ben
The build result when the MCP2515 component is present.
Compilation result without the MCP2515 component.
Target folder: C:\ElektronikProjeler\ESPtest\led test
Source name: C:\ElektronikProjeler\ESPtest\led test\led test.fcfx
Title:
Description:
Device: ESP.ESP32.ESP32_WROOM_32
Generated by: Flowcode v10.1.2.40
Date: Monday, September 15, 2025 14:11:42
Users: 1
Registered to: mehmet64 (99154532)
Licence key: 9P152P
https://www.flowcode.co.uk
Using FCD settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat "C:\FC_ESP\frameworks\esp-idf-v5.5\" "led test" "C:\ElektronikProjeler\ESPtest\led test\" esp32s_sdkconfig esp32
C:\ElektronikProjeler\ESPtest\led test>REM CRC: 0796FC1E6A776AF9156B257209C35258CE7C28B3EC20AEA2C632DB392A0E4BFD5B3F53B21811978F7B21FE4085045A7E774D1D3D69D8A99EE7320EAE740A5DB60228F42835EF5B88138FDEE58A4EE9C3A4BAF1B34E38B68E0C3CAEE8E7DA6987B808018476405B65B199900461C78937B42DEF8219F63A24580137A2F6C8FDB7553324EFF791947E8AB6FFD612B81BAA97C798A8F1CFC189DE5D38517747C774AF2DD6F839BAECF83F7F994C7164CE77868F480396BDEF2F2C3050DA273BE4EE69F15C302679453617F9EA00A6A8712D05E485F25DB02304E4565E63FDA312627DD474674123A97D
C:\ElektronikProjeler\ESPtest\led test>REM REVISION: 15.0
C:\ElektronikProjeler\ESPtest\led test>REM GUID: 955EA920-4961-4C53-BA6B-EF4AF66BB4C2
C:\ElektronikProjeler\ESPtest\led test>REM DATE: 07\04\2025
C:\ElektronikProjeler\ESPtest\led test>REM DIR: FCD\ESP\Batch\esp32_build.bat
============================== Toolchain Check ==============================
Python 3.13.7
git version 2.51.0.windows.1
ESP toolchain found at "C:\FC_ESP\frameworks\esp-idf-v5.5\"
Building: led test ...
IDF Version: v5.5 ...
Activating ESP-IDF 5.5
Setting IDF_PATH to 'C:\FC_ESP\frameworks\esp-idf-v5.5'.
* Checking python version ...
3.13.7
* Checking python dependencies ...
OK
* Deactivating the current ESP-IDF environment (if any) ...
OK
* Establishing a new ESP-IDF environment ...
OK
* Identifying shell ...
cmd.exe
* Detecting outdated tools in system ...
Found tools that are not used by active ESP-IDF version.
For removing old versions of idf-driver, idf-python-wheels use command 'python.exe C:\FC_ESP\frameworks\esp-idf-v5.5\tools\idf_tools.py uninstall'
To free up even more space, remove installation packages of those tools.
Use option python.exe C:\FC_ESP\frameworks\esp-idf-v5.5\tools\idf_tools.py uninstall --remove-archives.
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
Target: esp32 ...
[1/10] Performing build step for 'bootloader'
[1/1] C:\Windows\system32\cmd.exe /C "cd /D C:\FC_ESP\frameworks\esp-idf-v5.5\mtxesp32s_sdkconfig\build\bootloader\esp-idf\esptool_py && C:\FC_ESP\python_env\idf5.5_py3.13_env\Scripts\python.exe C:/FC_ESP/frameworks/esp-idf-v5.5/components/partition_table/check_sizes.py --offset 0x8000 bootloader 0x1000 C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/bootloader/bootloader.bin"
Bootloader binary size 0x6680 bytes. 0x980 bytes (8%) free.
[2/10] No install step for 'bootloader'
[3/10] Completed 'bootloader'
[4/10] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
ccache C:\FC_ESP\tools\xtensa-esp-elf\esp-14.2.0_20241119\xtensa-esp-elf\bin\xtensa-esp32-elf-gcc.exe -DESP_PLATFORM -DIDF_VER=\"v5.5-dirty\" -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -DSOC_MMU_PAGE_SIZE=CONFIG_MMU_PAGE_SIZE -DSOC_XTAL_FREQ_MHZ=CONFIG_XTAL_FREQ -DUNITY_INCLUDE_CONFIG_H -D_GLIBCXX_HAVE_POSIX_SEMAPHORE -D_GLIBCXX_USE_POSIX_SEMAPHORE -D_GNU_SOURCE -D_POSIX_READER_WRITER_LOCKS -IC:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/config -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/newlib/platform_include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/freertos/config/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/freertos/config/include/freertos -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/freertos/config/xtensa/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/freertos/FreeRTOS-Kernel/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/freertos/FreeRTOS-Kernel/portable/xtensa/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/freertos/FreeRTOS-Kernel/portable/xtensa/include/freertos -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/freertos/esp_additions/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/include/soc -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/include/soc/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/dma/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/ldo/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/debug_probe/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/mspi_timing_tuning/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/mspi_timing_tuning/tuning_scheme_impl/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/power_supply/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/port/esp32/. -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hw_support/port/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/heap/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/heap/tlsf -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/log/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/soc/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/soc/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/soc/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/soc/esp32/register -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/hal/platform_port/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/hal/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/hal/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_rom/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_rom/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_rom/esp32/include/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_rom/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_common/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_system/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_system/port/soc -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_system/port/include/private -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/xtensa/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/xtensa/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/xtensa/deprecated_include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/include/apps -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/include/apps/sntp -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/lwip/src/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/port/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/port/freertos/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/port/esp32xx/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/port/esp32xx/include/arch -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/lwip/port/esp32xx/include/sys -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_gpio/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_pm/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mbedtls/port/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mbedtls/mbedtls/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mbedtls/mbedtls/library -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mbedtls/esp_crt_bundle/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mbedtls/mbedtls/3rdparty/everest/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mbedtls/mbedtls/3rdparty/p256-m -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mbedtls/mbedtls/3rdparty/p256-m/p256-m -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_app_format/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_bootloader_format/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/app_update/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bootloader_support/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bootloader_support/bootloader_flash/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_partition/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/efuse/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/efuse/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_mm/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/spi_flash/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_security/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/pthread/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/compon
ents/esp_timer/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_gptimer/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_ringbuf/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_uart/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/vfs/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/app_trace/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_event/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/nvs_flash/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_phy/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_phy/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_usb_serial_jtag/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_vfs_console/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_netif/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/wpa_supplicant/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/wpa_supplicant/port/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/wpa_supplicant/esp_supplicant/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_coex/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_wifi/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_wifi/include/local -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_wifi/wifi_apps/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_wifi/wifi_apps/nan_app/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_spi/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_gdbstub/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/include/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/osi/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/api/include/api -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/btc/profile/esp/blufi/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/btc/profile/esp/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/hci_log/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/ble_log/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/host/bluedroid/api/include/api -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/tinycrypt/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/bt/common/tinycrypt/port -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/unity/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/unity/unity/src -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/cmock/CMock/src -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/console -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_pcnt/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_mcpwm/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_ana_cmpr/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_i2s/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/sdmmc/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_sdmmc/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_sdspi/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_sdio/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_dac/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_bitscrambler/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_rmt/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_tsens/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_sdm/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_i2c/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_ledc/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_parlio/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_twai/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/driver/deprecated -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/driver/i2c/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/driver/touch_sensor/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/driver/twai/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/driver/touch_sensor/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/http_parser -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp-tls -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp-tls/esp-tls-crypto -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_adc/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_adc/interface -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_adc/esp32/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_adc/deprecated/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_isp/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_cam/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_cam/interface -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_psram/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_jpeg/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_ppa/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_driver_touch_sens/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/
esp_driver_touch_sens/hw_ver1/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_eth/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_hid/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/tcp_transport/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_http_client/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_http_server/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_https_ota/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_https_server/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_lcd/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_lcd/interface -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/protobuf-c/protobuf-c -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/protocomm/include/common -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/protocomm/include/security -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/protocomm/include/transports -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/protocomm/include/crypto/srp6a -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/protocomm/proto-c -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/esp_local_ctrl/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/espcoredump/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/espcoredump/include/port/xtensa -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/wear_levelling/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/fatfs/diskio -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/fatfs/src -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/fatfs/vfs -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/idf_test/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/idf_test/include/esp32 -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/ieee802154/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/json/cJSON -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/mqtt/esp-mqtt/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/nvs_sec_provider/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/perfmon/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/rt/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/spiffs/include -IC:/FC_ESP/frameworks/esp-idf-v5.5/components/wifi_provisioning/include -mlongcalls -Wno-frame-address -fno-builtin-memcpy -fno-builtin-memset -fno-builtin-bzero -fno-builtin-stpcpy -fno-builtin-strncpy -fdiagnostics-color=always -ffunction-sections -fdata-sections -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=unused-but-set-variable -Wno-error=deprecated-declarations -Wextra -Wno-error=extra -Wno-unused-parameter -Wno-sign-compare -Wno-enum-conversion -gdwarf-4 -ggdb -Og -fno-shrink-wrap -fmacro-prefix-map=C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig=. -fmacro-prefix-map=C:/FC_ESP/frameworks/esp-idf-v5.5=/IDF -fstrict-volatile-bitfields -fno-jump-tables -fno-tree-switch-conversion -std=gnu17 -Wno-old-style-declaration -Wno-cpp -Wno-unused-function -Wno-unused-variable -Wno-unused-but-set-variable -Wno-incompatible-pointer-types -Wno-discarded-qualifiers -Wno-int-conversion -Wno-pointer-sign -MD -MT esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj -MF esp-idf\main\CMakeFiles\__idf_main.dir\esp-project.c.obj.d -o esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj -c C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/main/esp-project.c
from C:\ElektronikProjeler\ESPtest\led test\led test.h:238,
from C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/main/esp-project.c:20:
Running ninja in directory C:\FC_ESP\frameworks\esp-idf-v5.5\mtxesp32s_sdkconfig\build
Build Failed.
FINISHED
Title:
Description:
Date: Monday, September 15, 2025 14:13:46
Users: 1
Licence key: 9P152P
Python 3.13.7
3.13.7
OK
OK
OK
cmd.exe
idf.py build
Target: esp32 ...
[5/10] Linking C static library esp-idf\main\libmain.a
[6/10] Generating esp-idf/esp_system/ld/sections.ld
[7/10] Building C object CMakeFiles/esp-project.elf.dir/project_elf_src_esp32.c.obj
[8/10] Linking CXX executable esp-project.elf
[9/10] Generating binary image from built executable
esptool.py v4.10.dev2
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
Generated C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/esp-project.bin
[10/10] C:\Windows\system32\cmd.exe /C "cd /D C:\FC_ESP\frameworks\esp-idf-v5.5\mtxesp32s_sdkconfig\build\esp-idf\esptool_py && C:\FC_ESP\python_env\idf5.5_py3.13_env\Scripts\python.exe C:/FC_ESP/frameworks/esp-idf-v5.5/components/partition_table/check_sizes.py --offset 0x8000 partition --type app C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/partition_table/partition-table.bin C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/esp-project.bin"
esp-project.bin binary size 0x36e20 bytes. Smallest app partition is 0x100000 bytes. 0xc91e0 bytes (79%) free.
Project build complete. To flash, run:
idf.py flash
or
idf.py -p PORT flash
or
python -m esptool --chip esp32 -b 460800 --before default_reset --after hard_reset write_flash --flash_mode dio --flash_size 2MB --flash_freq 40m 0x1000 build\bootloader\bootloader.bin 0x8000 build\partition_table\partition-table.bin 0x10000 build\esp-project.bin
or from the "C:\FC_ESP\frameworks\esp-idf-v5.5\mtxesp32s_sdkconfig\build" directory
python -m esptool --chip esp32 -b 460800 --before default_reset --after hard_reset write_flash "@flash_args"
Get Project Build Statistics
[1/4] C:\Windows\system32\cmd.exe /C "cd /D C:\FC_ESP\frameworks\esp-idf-v5.5\mtxesp32s_sdkconfig\build\esp-idf\esptool_py && C:\FC_ESP\python_env\idf5.5_py3.13_env\Scripts\python.exe C:/FC_ESP/frameworks/esp-idf-v5.5/components/partition_table/check_sizes.py --offset 0x8000 partition --type app C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/partition_table/partition-table.bin C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/esp-project.bin"
[2/4] Performing build step for 'bootloader'
[3/4] No install step for 'bootloader'
[4/4] Completed 'bootloader'
[0/1] C:\Windows\system32\cmd.exe /C "cd /D C:\FC_ESP\frameworks\esp-idf-v5.5\mtxesp32s_sdkconfig\build && C:\FC_ESP\tools\cmake\3.30.2\bin\cmake.exe -D IDF_SIZE_TOOL=C:/FC_ESP/python_env/idf5.5_py3.13_env/Scripts/python.exe;-m;esp_idf_size -D MAP_FILE=C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/esp-project.map -D OUTPUT_JSON= -P C:/FC_ESP/frameworks/esp-idf-v5.5/tools/cmake/run_size_tool.cmake"
Memory Type Usage Summary
| Memory Type/Section | Used [bytes] | Used [%] | Remain [bytes] | Total [bytes] |
| Flash Code | 107570 | | | |
| .text | 107570 | | | |
| IRAM | 58151 | 44.37 | 72921 | 131072 |
| .text | 57123 | 43.58 | | |
| .vectors | 1028 | 0.78 | | |
| Flash Data | 44596 | | | |
| .rodata | 44340 | | | |
| .appdesc | 256 | | | |
| DRAM | 16676 | 13.39 | 107904 | 124580 |
| .data | 14332 | 11.5 | | |
| .bss | 2344 | 1.88 | | |
| RTC FAST | 32 | 0.39 | 8160 | 8192 |
| .force_fast | 32 | 0.39 | | |
| RTC SLOW | 24 | 0.29 | 8168 | 8192 |
| .rtc_slow_reserved | 24 | 0.29 | | |
Total image size: 224681 bytes (.bin may be padded larger)
Note: The reported total sizes may be smaller than those in the technical reference manual due to reserved memory and application configuration. The total flash size available for the application is not included by default, as it cannot be reliably determined due to the presence of other data like the bootloader, partition table, and application partition size.
Executing action: size
Executing "ninja size"...
Build completed successfully
Using FCD settings for linker
C:\Program Files (x86)\Flowcode v10\tools\DoNothing\DoNothing.exe
FINISHED
Sadık Süme
celebriums
Dear Dutch, I think I found the problem.
I deleted the component and added it again.
I changed the processor connections.
CHANNEL: Software
MOSI: PORTA23
MISO: PORTA22
CLK: PORTA1
SS: PORTA3
CHANNEL: Software
MOSI: PORTA23
MISO: PORTA22
CLK: PORTA1
SS: PORTA3
Source name: C:\ElektronikProjeler\ESPtest\led test\led test run setting.fcfx
Title:
Description:
Date: Monday, September 15, 2025 14:25:01
Users: 1
Licence key: 9P152P
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat "C:\FC_ESP\frameworks\esp-idf-v5.5\" "led test run setting" "C:\ElektronikProjeler\ESPtest\led test\" esp32s_sdkconfig esp32
Python 3.13.7
Building: led test run setting ...
3.13.7
OK
OK
OK
cmd.exe
idf.py build
Target: esp32 ...
[2/9] No install step for 'bootloader'
[3/9] Completed 'bootloader'
[4/9] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
[5/9] Linking C static library esp-idf\main\libmain.a
[6/9] Generating esp-idf/esp_system/ld/sections.ld
[7/9] Linking CXX executable esp-project.elf
[8/9] Generating binary image from built executable
[9/9] C:\Windows\system32\cmd.exe /C "cd /D C:\FC_ESP\frameworks\esp-idf-v5.5\mtxesp32s_sdkconfig\build\esp-idf\esptool_py && C:\FC_ESP\python_env\idf5.5_py3.13_env\Scripts\python.exe C:/FC_ESP/frameworks/esp-idf-v5.5/components/partition_table/check_sizes.py --offset 0x8000 partition --type app C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/partition_table/partition-table.bin C:/FC_ESP/frameworks/esp-idf-v5.5/mtxesp32s_sdkconfig/build/esp-project.bin"
esp-project.bin binary size 0x37370 bytes. Smallest app partition is 0x100000 bytes. 0xc8c90 bytes (78%) free.
idf.py flash
or
or
| Flash Code | 108914 | | | |
| .text | 108914 | | | |
| DRAM | 16700 | 13.41 | 107880 | 124580 |
| .data | 14348 | 11.52 | | |
| .bss | 2352 | 1.89 | | |
Total image size: 226041 bytes (.bin may be padded larger)
FINISHED
- led test run setting.fcfx
- (12.34 KiB) Downloaded 553 times
- (view online)
Sadık Süme
Thank you Ben and Celebriums.
I was out of the country for work. Now back on this subject I posted before I left.
I also updated the components.
I changed the default connections and now it’s compiling for external mcp2515. so i can at least work on my program. strange i overlooked that.
Internal 'mcp' is still producing a (cannot find driver/can.h?) fault. I see my toolchain ISP-IDF is still 5.3.1
How can i select or upload another compiler for ESP ?. i see there is only 'Default' and a possibility to upload and .fcs file.
There are newer 5.5.1 files on line but these are not a .fcs file is suppose but 1,5G of data
I hope Ben can find the issue and tell us how to update or fix it.
- test led .docx
- (188.64 KiB) Downloaded 553 times
Just purchased the licence for the complete ESP package.
So far i cannot get any Build successful from the first four ESP32-C3 options. (the on board led is here GPIO8).
I have ordered an number of ESP32-C3 supermini boards because these are smaller. Because the build fails, i compiled the 'normal' ESP32, but that fails because it detects an ESP-C3. What tells me the USBc cable and module are recognised
If you can compile this file for example to HEX successfully let me know. Curious.
- c3 mini led stest.fcfx
- (7.7 KiB) Downloaded 536 times
- (view online)
Sorry I have now looked into the problem again and it seems to stem from the fact that espressif have changed CAN to TWAI in their latest version of IDF. TWAI - Two Wire Automotive Interface.
I've updated the CAL CAN file to change the include from can.h to twai.h and a lot of other instances of CAN throughout the file and this now seems to compile ok.
What prompted them to make the change I'm not sure. There's a rant about it here if you're interested.
https://github.com/espressif/esp-idf/issues/5580
Let us know how you get on.
Hello Ben, is there anway to test 5.5 for ISP-IDF?
Intresting article. And it already dates back to 2021.
Hello Ben, is there an update needed for the ' internal MCP2515' to work because you updated the CAL CAN file to change the include from can.h to twai.h, or is there one planned? The current compiler still includes can.h
Unfortunately the 'external mcp2515' is not producing the signals on the given pins. So my hope is on the internal one now. The one i wanted to use anyway in the end.
Could you please tell me how to get the update?
This below is from minutes ago all checks done for updates. Core sw patch gives error because latest is already on it.
I did cutout a lot of text. if needed i can of coarse put all. but i think the point is clear
Target: esp32 ...
Build Failed.
FINISHED
Target: esp32 ...
Build Failed.
FINISHED
