bug with pca9685
aderito
Has thanked: 19 times
Been thanked: 2 times
bug with pca9685
Post by aderito »
Hi, I came here to report what I think is a bug with the "pca9685" component.
After some time trying to get it to work with a simple test program, I discovered that in the properties window for this component, if both channel 1 and channel 2 are selected, it simply doesn't work.
However, if software mode is selected, it works without any problems.
Any ideas?
Thanks in advance.
aderito
Re: bug with pca9685
Post by aderito »
here are the related files
teste proteus.jpg (213.56 KiB) Viewed 7776 times
PCA9685.fcfx
(11.8 KiB) Downloaded 339 times
flowcode configuracao.jpg (96.66 KiB) Viewed 7776 times
Has thanked: 794 times
Been thanked: 858 times
Have you tried using Embedded hardware or just simulating?
There are occasions where the simulator is the issue and I want avoid that.
Can you let me know if hardware has the same issue?
aderito
Post by aderito »
Hi Martin, thanks for the reply.
I've only simulated with Proteus so far, but what I noticed was the difference in setup times during the four macros (separated by a 1-second delay) before entering the loop.
I don't yet have the PCB with the PCA9685 chip physically with me to test.
I usually test with Proteus whenever possible before moving on to the "physical" part, and so far I haven't had any problems.
If anyone here has the opportunity to test with hardware, that would be great.
aderito
Post by aderito »
I'm out at the moment, as soon as I can I'll take a screen capture with the software configuration and the dedicated channel configuration.
aderito
Post by aderito »
As promised, I will post 6 screenshots. The first 3 refer to the configuration in "software" mode and the next 3 in "channel 1" mode.
teste proteus channel 1_3.jpg (182.78 KiB) Viewed 7716 times
teste proteus channel 1_2.jpg (183.05 KiB) Viewed 7716 times
teste proteus channel 1_1.jpg (181.35 KiB) Viewed 7716 times
aderito
Post by aderito »
each capture represents the three configuration steps plus the loop
aderito
Post by aderito »
These three screenshots refer to software mode
teste proteus software 3.jpg (182.34 KiB) Viewed 7715 times
teste proteus software 2.jpg (183.28 KiB) Viewed 7715 times
teste proteus software 1.jpg (182.06 KiB) Viewed 7715 times
aderito
Post by aderito »
The simulation order is: 1,2,3 for software mode and: 1_1,1_2,1_3
for channel 1.
For reference, the same tests were performed on channel 2 and the results were the same.
aderito
Post by aderito »
this is the test program
PCA9685.fcfx
(11.72 KiB) Downloaded 347 times
