Hi, I came here to report what I think is a bug with the "pca9685" component.
After some time trying to get it to work with a simple test program, I discovered that in the properties window for this component, if both channel 1 and channel 2 are selected, it simply doesn't work.
However, if software mode is selected, it works without any problems.
Any ideas?
Thanks in advance.
bug with pca9685
aderito
- Has thanked: 19 times
- Been thanked: 2 times
aderito
Re: bug with pca9685
here are the related files
- teste proteus.jpg (213.56 KiB) Viewed 7799 times
- PCA9685.fcfx
- (11.8 KiB) Downloaded 348 times
- (view online)
- flowcode configuracao.jpg (96.66 KiB) Viewed 7799 times
- Has thanked: 800 times
- Been thanked: 865 times
Have you tried using Embedded hardware or just simulating?
There are occasions where the simulator is the issue and I want avoid that.
Can you let me know if hardware has the same issue?
aderito
Hi Martin, thanks for the reply.
I've only simulated with Proteus so far, but what I noticed was the difference in setup times during the four macros (separated by a 1-second delay) before entering the loop.
I don't yet have the PCB with the PCA9685 chip physically with me to test.
I usually test with Proteus whenever possible before moving on to the "physical" part, and so far I haven't had any problems.
If anyone here has the opportunity to test with hardware, that would be great.
aderito
As promised, I will post 6 screenshots. The first 3 refer to the configuration in "software" mode and the next 3 in "channel 1" mode.
- teste proteus channel 1_3.jpg (182.78 KiB) Viewed 7739 times
- teste proteus channel 1_2.jpg (183.05 KiB) Viewed 7739 times
- teste proteus channel 1_1.jpg (181.35 KiB) Viewed 7739 times
aderito
These three screenshots refer to software mode
- teste proteus software 3.jpg (182.34 KiB) Viewed 7738 times
- teste proteus software 2.jpg (183.28 KiB) Viewed 7738 times
- teste proteus software 1.jpg (182.06 KiB) Viewed 7738 times
aderito
The simulation order is: 1,2,3 for software mode and: 1_1,1_2,1_3
for channel 1.
For reference, the same tests were performed on channel 2 and the results were the same.
for channel 1.
aderito
this is the test program
- PCA9685.fcfx
- (11.72 KiB) Downloaded 348 times
- (view online)
