Compilation error of the DSP_DLace component
Post by 17712885438 »
DSP_DLace.fcfx
(11.13 KiB) Downloaded 193 times
Please help me, thank you
Target folder: E:\flowcode exp
Source name: E:\flowcode exp\Flowcode1.fcfx
Title:
Description:
Device: AVR.ATMEGA.ATMEGA128
Generated by: Flowcode v10.1.2.40
Date: Monday, October 27, 2025 08:52:30
Users: 1
Registered to: niedian (33762713)
Licence key: AF2WAB
https://www.flowcode.co.uk
Using <USB Tiny> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avr\" atmega128 "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" "E:\flowcode exp\Flowcode1.lst"
E:\flowcode exp>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF5A24465F11D9C3B2DBA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EE1FA30153290F2FAFBD2259D77AD477809E9C4D76400384BA5D2E1919BC6D834D57C406BC4A49D3F1
E:\flowcode exp>REM REVISION: 1.0
E:\flowcode exp>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
E:\flowcode exp>REM DATE: 08\08\2022
E:\flowcode exp>REM DIR: FCD\AVR\batchfiles\avra.bat
E:\flowcode exp>"C:\Program Files (x86)\Flowcode\Common\Compilers\avr\bin\avr-gcc.exe" -mmcu=atmega128 -Os -ffunction-sections -fdata-sections -funsigned-char -o "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" -lm -Wl,-gc-sections
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetInt':
E:\flowcode exp\Flowcode1.c:255: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c:255: error: (Each undeclared identifier is reported only once
E:\flowcode exp\Flowcode1.c:255: error: for each function it appears in.)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetLong':
E:\flowcode exp\Flowcode1.c:272: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetFloat':
E:\flowcode exp\Flowcode1.c:287: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetLong':
E:\flowcode exp\Flowcode1.c:304: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetInt':
E:\flowcode exp\Flowcode1.c:329: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetByte':
E:\flowcode exp\Flowcode1.c:356: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetByte':
E:\flowcode exp\Flowcode1.c:383: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetFloat':
E:\flowcode exp\Flowcode1.c:404: error: 'MX_Conv_Var' undeclared (first use in this function)
Error returned from [avr-gcc.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat reported error code 0x1
Autoclose turned off
FINISHED
Has thanked: 615 times
Been thanked: 814 times
Re: Compilation error of the DSP_DLace component
Many thanks for letting us know.
Hopefully all resolved for you now via the library updates.
I've also adjusted your program slightly to give you an example.
DSP_DLace.fcfx
(15.54 KiB) Downloaded 212 times
17712885438
DSP_ILace Compilation error.Please help me, thank you.
DSP_ILace.fcfx
(20.17 KiB) Downloaded 188 times
Title:
Description:
Device: ARD.ATMEGA.ATMEGA328P
Date: Wednesday, October 29, 2025 09:27:24
Users: 1
Licence key: AF2WAB
Using FCD settings for compiler
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avr\" atmega328p "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" "E:\flowcode exp\Flowcode1.lst"
E:\flowcode exp>"C:\Program Files (x86)\Flowcode\Common\Compilers\avr\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" -lm -Wl,-gc-sections
E:\flowcode exp\Flowcode1.c: In function 'FCD_0bb62_DSP_ILace1__Interlace':
E:\flowcode exp\Flowcode1.c:1223: error: 'FCV_0bb62_DSP_ILace1__INDEXIN1' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c:1223: error: (Each undeclared identifier is reported only once
E:\flowcode exp\Flowcode1.c:1223: error: for each function it appears in.)
FINISHED
17712885438
not DSP_DLace.but DSP_ILace.thank.
17712885438
DSP_DLace is OK! but DSP_ILace is error.
Has thanked: 724 times
Been thanked: 783 times
Hi.
Apologies, I misread.
This topic is now unlocked
