Compilation error of the DSP_DLace componentPlease help me, thank you
Target folder: E:\flowcode exp
Source name: E:\flowcode exp\Flowcode1.fcfx
Title:
Description:
Device: AVR.ATMEGA.ATMEGA128
Generated by: Flowcode v10.1.2.40
Date: Monday, October 27, 2025 08:52:30
Users: 1
Registered to: niedian (33762713)
Licence key: AF2WAB
https://www.flowcode.co.uk
Using <USB Tiny> inbuilt settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avr\" atmega128 "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" "E:\flowcode exp\Flowcode1.lst"
E:\flowcode exp>REM CRC: EA277D0C7EF9B4E537B79187D0BE7A25FA6080B4B01BE48BAF713429E4B690411241251B4A05C2B5828F4452C9F7348705C640EF477B79E0C7881D2E5EEC9BD69A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF5A24465F11D9C3B2DBA3F4E37F13004EE3637760F1F0B7DA0CC623CD30E3C7D6BAB4C3FE6151D92B8EC0ADD55E96639DAC02472BDE3806EF43AE3A028BD32A5DAE68BB191DA97CB6883A66D3C41849952BB2DD264AF32733E2C3050DA273BE4EE1FA30153290F2FAFBD2259D77AD477809E9C4D76400384BA5D2E1919BC6D834D57C406BC4A49D3F1
E:\flowcode exp>REM REVISION: 1.0
E:\flowcode exp>REM GUID: EA0828B2-5C70-41A5-8C54-F359DD5CC88B
E:\flowcode exp>REM DATE: 08\08\2022
E:\flowcode exp>REM DIR: FCD\AVR\batchfiles\avra.bat
E:\flowcode exp>"C:\Program Files (x86)\Flowcode\Common\Compilers\avr\bin\avr-gcc.exe" -mmcu=atmega128 -Os -ffunction-sections -fdata-sections -funsigned-char -o "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" -lm -Wl,-gc-sections
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetInt':
E:\flowcode exp\Flowcode1.c:255: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c:255: error: (Each undeclared identifier is reported only once
E:\flowcode exp\Flowcode1.c:255: error: for each function it appears in.)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetLong':
E:\flowcode exp\Flowcode1.c:272: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetFloat':
E:\flowcode exp\Flowcode1.c:287: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetLong':
E:\flowcode exp\Flowcode1.c:304: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetInt':
E:\flowcode exp\Flowcode1.c:329: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetByte':
E:\flowcode exp\Flowcode1.c:356: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__GetByte':
E:\flowcode exp\Flowcode1.c:383: error: 'MX_Conv_Var' undeclared (first use in this function)
E:\flowcode exp\Flowcode1.c: In function 'FCD_02571_TypeConversionsFree1__SetFloat':
E:\flowcode exp\Flowcode1.c:404: error: 'MX_Conv_Var' undeclared (first use in this function)
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat reported error code 0x1
Autoclose turned off
FINISHED
17712885438
- Has thanked: 615 times
- Been thanked: 814 times
Re: Compilation error of the DSP_DLace component
Many thanks for letting us know.
Hopefully all resolved for you now via the library updates.
I've also adjusted your program slightly to give you an example.
17712885438
DSP_ILace Compilation error.Please help me, thank you.
Title:
Description:
Device: ARD.ATMEGA.ATMEGA328P
Date: Wednesday, October 29, 2025 09:27:24
Users: 1
Licence key: AF2WAB
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avra.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\avr\" atmega328p "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" "E:\flowcode exp\Flowcode1.lst"
E:\flowcode exp>"C:\Program Files (x86)\Flowcode\Common\Compilers\avr\bin\avr-gcc.exe" -mmcu=atmega328p -Os -ffunction-sections -fdata-sections -funsigned-char -o "E:\flowcode exp\Flowcode1.elf" "E:\flowcode exp\Flowcode1.c" -lm -Wl,-gc-sections
E:\flowcode exp\Flowcode1.c: In function 'FCD_0bb62_DSP_ILace1__Interlace':
error: 'FCV_0bb62_DSP_ILace1__INDEXIN1' undeclared (first use in this function)
FINISHED
Title:
Description:
Users: 1
Licence key: AF2WAB
FINISHED
17712885438
17712885438
