ESP32 Compiling error
Has thanked: 772 times
Been thanked: 831 times
Re: ESP32 Compiling error
Could an antivirus or firewall be preventing the option?
Has thanked: 245 times
Been thanked: 257 times
Hi Martin
I think it's something like this. So I found an info about an offline-installer.
I will try it next monday
ESP-IDF Tools Installer
What is the usecase for Online and Offline Installer
Online Installer is very small and allows the installation of all available releases of ESP-IDF. The installer will download only necessary dependencies including Git For Windows during the installation process. The installer stores downloaded files in the cache directory %userprofile%\.espressif
Offline Installer does not require any network connection. The installer contains all required dependencies including Git For Windows .
https://docs.espressif.com/projects/esp ... setup.html
Hi to All
I used the offline installer. While installing there was no error
C:\Users\stefan.erni\Desktop\esp-idf>python --version
Python 3.8.7
but if I compile to chip:
The following Python requirements are not satisfied:
click>=7.0
pyserial>=3.0
future>=0.15.2
cryptography>=2.1.4
pyparsing>=2.0.3,<2.4.0
pyelftools>=0.22
gdbgui==0.13.2.0
pygdbmi<=0.9.0.2
python-socketio<5
kconfiglib==13.7.1
reedsolo>=1.5.3,<=1.5.4
bitstring>=3.1.6
ecdsa>=0.16.0
construct==2.10.54
esp-windows-curses; sys_platform == 'win32'
To install the missing packages, please run "C:\Users\stefan.erni\Desktop\esp-idf\install.bat"
Diagnostic information:
IDF_PYTHON_ENV_PATH: C:\Users\stefan.erni\.espressif\python_env\idf4.3_py3.7_env
Python interpreter used: C:\Users\stefan.erni\.espressif\python_env\idf4.3_py3.7_env\Scripts\python.exe
Traceback (most recent call last):
File "C:\Users\stefan.erni\Desktop\esp-idf\tools\idf.py", line 47, in <module>
from idf_py_actions.tools import executable_exists, idf_version, merge_action_lists, realpath # noqa: E402
File "C:\Users\stefan.erni\Desktop\esp-idf\tools\idf_py_actions\tools.py", line 7, in <module>
import click
ModuleNotFoundError: No module named 'click'
Build Failed
Autoclose turned off
LeighM
Has thanked: 107 times
Been thanked: 302 times
Post by LeighM »
Try this ...
Run a Command Prompt
cd to the esp-idf directory e.g...
cd C:\Users\stefan.erni\Desktop\esp-idf
Then type/run
install.bat esp32
Hi Leigh
I've already done that, but it didn't help
LeighM
Post by LeighM »
Hi Stefan,
Looks like a Python issue, in that the extra packages have not been installed, or inaccessible by the version ESP thinks it’s using.
Do you have more than one version installed?
Might be worth uninstalling all Python, then trying again.
Leigh
jollybv
Has thanked: 42 times
Been thanked: 15 times
Post by jollybv »
hi guys
Just from my experience when I created the esp-idf folder it automatically creates another folder espressif and puts the file in that when I forced it to install in the esp-idf without the espressif folder everything worked.
Hi Jollybv, Hi Leigh
@Jollybv You mean for the second folder (.expressif) you choosed the same folder (on Desktop esp-if). I will try that.
@ Leigh Here is the version of Python and ESP-IF Tools on computer 1 (the one where works well) I will see what version are on the other computer and check if there are more than one version of Python.
jollybv
Post by jollybv »
Hi yes
you need to load it into just the ESP-IDF folder
Hi Leigh
There is the same Phyton but there is a Phython Launcher on the bad computer
