SPI Slave Compiler gives an error
Osta
Has thanked: 1 time
Been thanked: 5 times
Post by Osta »
Happy New Year everyone!!!
I use ATMEGA 128 controller.
When using interrupts and the SPI Slave macro compiler gives an error.
TEST.c:(.text.FCM_SSP+0x0): undefined reference to `FC_CAL_SPI_Slave_RxByte_1'
Set inter.jpg (36.51 KiB) Viewed 8194 times
TEST.fcfx
Test
(9.47 KiB) Downloaded 711 times
Has thanked: 647 times
Been thanked: 856 times
Re: SPI Slave Compiler gives an error
Hello and Happy new year :D
It looks like SPI slave functionality is not currently impemented on the AVR target devices.
I'll have a look for you now and see if I can add it in for you.
Hello again,
Right it's compiling correctly now and I've pushed the update to the library update system.
Let us know how you get on.
Osta
Has thanked: 1 time
Post by Osta »
Thanks a lot !!!!!!!
I updated the libraries and everything worked!
Best wishes to you and your team! ;)
Osta
Has thanked: 1 time
Post by Osta »
Again, error, but in another project with ATMEGA 128
Interrupts do not work ....
Osta
Has thanked: 1 time
Post by Osta »
Before using the Flowcode macros, the С code was written,
But after the use of macros Flowcode, the compiler began to issue an error!
As a result, neither macros do not work С code !!!
SPI.fcfx
(14.48 KiB) Downloaded 646 times
Osta
Has thanked: 1 time
Post by Osta »
I do not know what to do...
How to return to the scene when did you work with the code?
Has thanked: 795 times
Been thanked: 858 times
Hi.
The compiler is complaining that you have got the same interrupts enabled in Main and COXPAH.
If you remove one it should compile for you.
Osta
Has thanked: 1 time
Post by Osta »
Right!!!
Thanks a lot!!!
