Happy New Year everyone!!!
I use ATMEGA 128 controller.
When using interrupts and the SPI Slave macro compiler gives an error.
TEST.c:(.text.FCM_SSP+0x0): undefined reference to `FC_CAL_SPI_Slave_RxByte_1'
SPI Slave Compiler gives an error
Osta
- Has thanked: 1 time
- Been thanked: 5 times
- Set inter.jpg (36.51 KiB) Viewed 8201 times
- TEST.fcfx
- Test
- (9.47 KiB) Downloaded 711 times
- (view online)
- Has thanked: 647 times
- Been thanked: 856 times
Re: SPI Slave Compiler gives an error
Hello and Happy new year
It looks like SPI slave functionality is not currently impemented on the AVR target devices.
I'll have a look for you now and see if I can add it in for you.
Hello again,
Right it's compiling correctly now and I've pushed the update to the library update system.
Let us know how you get on.
Before using the Flowcode macros, the С code was written,
But after the use of macros Flowcode, the compiler began to issue an error!
As a result, neither macros do not work С code !!!
- SPI.fcfx
- (14.48 KiB) Downloaded 648 times
- (view online)
- Has thanked: 795 times
- Been thanked: 858 times
Hi.
The compiler is complaining that you have got the same interrupts enabled in Main and COXPAH.
If you remove one it should compile for you.
