Potentiometer not acting as analogue input
Mikeatukstemdotuk
Post by Mikeatukstemdotuk »
I have a10k pot with the wiper connected to A0 on an Arduiono R3. Setting a variable to be the value of this input doesn't seem to work. I'm trying o have the Pot control the off period for a flashing LED. When run the LED goes off for either 1s or 0s. Any help please. Thanks
Has thanked: 442 times
Been thanked: 661 times
Re: Potentiometer not acting as analogue input
Post by chipfryer27 »
If you could post your chart we can have a look and perhaps make suggestions.
Has thanked: 724 times
Been thanked: 783 times
Also, take a look here and see if it resolves your issue.
Mikeatukstemdotuk
Hi, apologies for delay - I've been away for a while.
(I'm not sure how to post the chart - the add picture function here doesn't work)
Is there support I can email to?
Has thanked: 234 times
Been thanked: 252 times
Hi Mikeatukstemdotuk
Can you try with drag and drop the picture? And resize the picture if it's large.
Has thanked: 292 times
Been thanked: 458 times
Mikeatukstemdotuk wrote:
Wed Oct 19, 2022 3:21 pm
Click the "full editor & preview" button to reply to this post and click the "add file" button in the "attachments" tab to attach your Flowcode project file.
Mikeatukstemdotuk
Hi When I click the 'add image button' I get this:
There is no 'add file' button that I can see
It will be here once you have clicked on the button to reply:
2022-10-19 17_12_28-Flowcode Support Board - Post a reply.png (13.35 KiB) Viewed 4152 times
Mikeatukstemdotuk
Hiya
See the attachments button now :D
Two files are there - neither of which works on Arduino although the simulation works fine
Flowcode 1.JPG (68.17 KiB) Viewed 4150 times
Please, always post your project file that ends with .fcfx as from the images we can't see your component property settings that can have an effect on your hardware.
