Potentiometer not acting as analogue input
Mikeatukstemdotuk
I have a10k pot with the wiper connected to A0 on an Arduiono R3. Setting a variable to be the value of this input doesn't seem to work. I'm trying o have the Pot control the off period for a flashing LED. When run the LED goes off for either 1s or 0s. Any help please. Thanks
- Has thanked: 442 times
- Been thanked: 661 times
Re: Potentiometer not acting as analogue input
If you could post your chart we can have a look and perhaps make suggestions.
Mikeatukstemdotuk
Hi, apologies for delay - I've been away for a while.
(I'm not sure how to post the chart - the add picture function here doesn't work)
Is there support I can email to?
- Has thanked: 234 times
- Been thanked: 252 times
Hi Mikeatukstemdotuk
Can you try with drag and drop the picture? And resize the picture if it's large.
- Has thanked: 292 times
- Been thanked: 458 times
Click the "full editor & preview" button to reply to this post and click the "add file" button in the "attachments" tab to attach your Flowcode project file.
Mikeatukstemdotuk
Hi When I click the 'add image button' I get this:
![Image]()
There is no 'add file' button that I can see
It will be here once you have clicked on the button to reply:
Mikeatukstemdotuk
Hiya
See the attachments button now
Two files are there - neither of which works on Arduino although the simulation works fine
- Flowcode2.JPG (58.87 KiB) Viewed 4141 times
- Flowcode 1.JPG (68.17 KiB) Viewed 4141 times
- Has thanked: 724 times
- Been thanked: 783 times
Please, always post your project file that ends with .fcfx as from the images we can't see your component property settings that can have an effect on your hardware.
