PIC18F45K40 UART PIN Mapping
seokgi
Has thanked: 8 times
Been thanked: 8 times
Post by seokgi »
Hello?
It's hard to find an MCU, so the MCU I finally got is the PIC18F45K40.
I want to receive GPIO input as Low Active or High Active. But it doesn't work correctly. So I'm using it in reverse. Any good way?
Next question. I want to use two UARTs in PIC18F45K40-I/PT. B Port is set well. However, C Port is not set and an error occurs. In the manual, C7 (Pin No. 1) is indicated as RX1. It would be nice to set it to a port supported by FC9, but many PCBs have already been made.
Please help.
Thank you.
Has thanked: 724 times
Been thanked: 783 times
Re: PIC18F45K40 UART PIN Mapping
For the GPIO input active low for example, I have mentioned that here
For the UART component, you can only select ports that are designed to be available by the manufacturer.
From the datasheet (I have blanked the 28-pin ports), here are the available ports for channel1 and channel2.
Remap Pins UART Component.png (75.8 KiB) Viewed 3766 times
As you can see, only B and C are avaiable for Channel2
If you want to use port C for both channels, then instead of using channel2 you could use the UART software (Timer) component.
seokgi
Post by seokgi »
Thank you for quick response.
In FC9, Channel1 has only B and D Port options. Occasionally, I see Port C. But when I compile, I get an error. C Port cannot be selected.
If you only can only see port B and D with channel1 then select a random pin.
It should then change from port D to Port C so you can then select the correct port C pin.
If you are still having issues can you either post your project file or PM it, if you want it to remain private?
seokgi
Post by seokgi »
Thank you.
That way C7 is sometimes set. However, after a while, it is changed back to D7 in an unrecognized situation. And when compiling in C7 state, a compile error appears.
It's my PG
221102-01-PRT2COM.fcfx
(57.51 KiB) Downloaded 411 times
Has thanked: 616 times
Been thanked: 815 times
What error message are you getting.
I tried the following and it's compiling fine for me, reloading the project and still ok and assigned correctly.
ModbusSlave to Channel 1 TX C6 and RX C7
Monitor_Send to Channel 2 TX B6 and RX B7
You might need to check your using the latest version of the files by going to Help -> Library Updates.
Here's the project with my property changes.
(57.72 KiB) Downloaded 516 times
seokgi
Post by seokgi »
Thanks for your help, it worked out well. thank you.
