Hello?
It's hard to find an MCU, so the MCU I finally got is the PIC18F45K40.
I want to receive GPIO input as Low Active or High Active. But it doesn't work correctly. So I'm using it in reverse. Any good way?
Next question. I want to use two UARTs in PIC18F45K40-I/PT. B Port is set well. However, C Port is not set and an error occurs. In the manual, C7 (Pin No. 1) is indicated as RX1. It would be nice to set it to a port supported by FC9, but many PCBs have already been made.
Please help.
Thank you.
PIC18F45K40 UART PIN Mapping
seokgi
- Has thanked: 8 times
- Been thanked: 8 times
- Has thanked: 724 times
- Been thanked: 783 times
Re: PIC18F45K40 UART PIN Mapping
For the GPIO input active low for example, I have mentioned that here
For the UART component, you can only select ports that are designed to be available by the manufacturer.
From the datasheet (I have blanked the 28-pin ports), here are the available ports for channel1 and channel2. As you can see, only B and C are avaiable for Channel2
If you want to use port C for both channels, then instead of using channel2 you could use the UART software (Timer) component.
If you only can only see port B and D with channel1 then select a random pin.
It should then change from port D to Port C so you can then select the correct port C pin.
If you are still having issues can you either post your project file or PM it, if you want it to remain private?
Thank you.
That way C7 is sometimes set. However, after a while, it is changed back to D7 in an unrecognized situation. And when compiling in C7 state, a compile error appears.
It's my PG
It's my PG
- 221102-01-PRT2COM.fcfx
- (57.51 KiB) Downloaded 410 times
- Has thanked: 616 times
- Been thanked: 815 times
What error message are you getting.
I tried the following and it's compiling fine for me, reloading the project and still ok and assigned correctly.
ModbusSlave to Channel 1 TX C6 and RX C7
Monitor_Send to Channel 2 TX B6 and RX B7
You might need to check your using the latest version of the files by going to Help -> Library Updates.
Here's the project with my property changes.
