ESP toolchain do not accepted in FC V9
Sergejs
Has thanked: 75 times
Been thanked: 5 times
Post by Sergejs »
I downlload and install ESP toolchain for ESP32 but when I try to compile the project I always see: visit site and download toolchain. What can I do?
Has thanked: 772 times
Been thanked: 831 times
Re: ESP toolchain do not accepted in FC V9
You need to follow page 8 (Flowcode Configuration) In the ESP Installation Instructions
Sergejs
Post by Sergejs »
Many thanks!
Sergejs
Post by Sergejs »
Sorry, but it does not work. You can see attachement.
Has thanked: 245 times
Been thanked: 257 times
Hi Sergejs
Can you post your program?
Hi Sergejs.
Can you also post your Project name.msg.txt file
Unfortunately, screenshots like the one you posted does not help us to help you at all.
Most issues are caused by using a later-than-suggested version of ESP-IDF.
Take a look at this post.
Sergejs
Post by Sergejs »
Hi, this is file you ask.
ESP32.msg.txt
(19.67 KiB) Downloaded 430 times
Sergejs
Post by Sergejs »
medelec35 wrote:
Thu Feb 02, 2023 8:03 am
How I understand there is not compatible with V9 or compiler wrong.
Has thanked: 634 times
Been thanked: 842 times
It looks like you are using the latest ESP-IDF (5.0) which is not supported, we recommend using version 4.1 in the installation guide.
There is a way to roll back the IDF which we document here.
viewtopic.php?p=9222#p9222
We are investigating adding support for the latest version but a lot of things has changed and so needs to be done in a careful way to avoid breaking functionality.
