Ribbon Toolbar
Revision as of 14:37, 26 October 2020 by BenR (talk | contribs) (Icons Toolbar)
Introduction
The Flowcode environment consists of a main work area in which the flowchart windows are displayed, several toolbars that allow icon and components to be added to the flowchart application, windows that allow the status of the microcontroller and attached components to be viewed and windows that display variables and macro calls when the flow chart is being simulated.
From the View menu you are able to customise Flowcode to hide and display panel windows such as the Dashboard Panel, System Panel, Properties Panel, Component Debugger and much more, you can also show / hide the Toolbars referenced as Toolboxes, e.g. the 'Main Toolbar', 'Components Toolbar' or rather Toolbox, as well as the 'Icons Toolbar' otherwise known as the 'Command Toolbox'
File Menu
The file menu allows you to start a new project, open an existing project and save a project.
You can also import a 3D model onto the 3D panel and export the project as a component or App Deleoper application.
Edit Toolbar
The edit toolbar provides some common items to simplify program editing such as copy, paste and icon grouping.
  • Undo - Moves back a step in the Change_History.
  • Redo - Moves forward a step in the Change_History.
  • Cut - Cuts the selected flowchart / state machine / component to the clipboard.
  • Copy - Copies the selected flowchart / state machine / component to the clipboard.
  • Paste - Pastes the contents of the clipboard into the code view / panel.
  • Delete - Deletes the selected flowchart / state machine / component from the project.
  • Bookmark - Bookmarks a flowchart / state machine icon.
  • Annotation - Controls the annotation style allowing you to make all annotations visible or invisible.
  • Group - Groups the selected flowchart icons together into a single group icon.
  • Ungroup - Ungroups a group icon back into individual flowchart icons.
  • Customise C Code - Allows the generated C code for an icon to be overridden.
  • Toggle Disable - Allows an icon or selection of icons to be disabled or re-enabled.
  • Properties - Goes into the icon properties for the selected icon.
  • Key Mappings - Edits the simulation keyboard mappings.
View Toolbar
The following elements can be switched on and off using the view toolbar section of the main ribbon.
  • Project Explorer - The project explorer allows you to easily manipulate the key constituents of your project. Left clicking on the arrow or right clicking on the various objects in the explorer will bring up a menu relevant to that object. The 'Macro' and 'Components' icons can be dragged into the main window to be placed as icons.
  • 2D: Dashboard Panel - The Dashboard Panel provides a 2D window on which to load Flowcode components. It can be used for any component but is suited towards none 3D components such as buttons, switches, displays.
  • 3D System Panel - The System Panel provides a 3D (real-world) framework on which to load Flowcode components to provide a 3D simulation. It can be used for most components however will not work with the new 2D only GUI simulation components.
  • Component Properties - The component properties window allows you to view and edit settings specific to the current selected component. The top of the window features a drop down list which lists all of the panel components included in the project.
  • Find_and_Replace - The find and replace window allows you to search the current macro or project for a keyword and provides means to replace the keyword and filter by icon type.
  • Change History - A text based history of recent changes in the program allowing you to jump forwards and backward through the change history.
  • Data Recorder - A means to see waveform history during simulation or using Ghost enabled hardware.
  • Oscilloscope - A means to see repeating waveforms as you would on a standard oscilloscope during simulation or using Ghost enabled hardware.
  • Consoles - Used for textual based logs or debugging, various components may create a tab on the console to allow you to easily see data flow or other debugging data.
  • Component_Debugger - Used to provide addition advanced debugging when creating components, allows you to look inside the component object tree as well as monitor Flowcode execution events and debug messages.
  • Analog Window - The analogue inputs window monitors the various analogue input pins on the selected target microcontroller device.
  • Digital Pins - The digital pins window monitors the various digital input / output pins on the selected target microcontroller device.
  • Watch Window - This window appears when simulating a flowchart, it shows the current macro being simulated as well as the values of any variables selected, the values of the variables are updated for every command simulated but does not update when running the simulation 'As fast as possible'.When simulating a flowchart, the values of any variables used can be seen in this view. The values of the variables are updated for every command simulated but the view is not updated when the simulation is running at full speed.
  • Wiki
  • Licensing
  • Forums
  • Target Device - The pins of the selected target microcontroller is displayed in this window. When the flowchart is being simulated, the state of the microcontroller I/O ports are shown on the microcontroller as red and grey for high and low outputs respectively.
  • Icon Lists - This window shows a list of the icons that: have been bookmarked; are set as breakpoints; are search results or have shown to cause an error after compilation. Left clicking on the arrow or right clicking on the various objects in the icon list will bring up a menu relevant to that object.
  • Zoom - The currently selected Zoom level is displayed on the right side of the Status Bar. You can change the 'Zoom' using keyboard shortcuts such as F2 to 'Decrease' the zoom, F3 to 'Increase' the zoom and F4 to set the zoom at '75%' you can also select the options in the 'Zoom' sub-menu in the 'View' menu (View > Zoom > ), this menu also displays the 'Current zoom' level and allows you to change the zoom to 25%, 50%, 75% or 100% as well as the ability to 'Zoom to Fit' and 'Zoom to Fit Width'.
  • Global Settings - A window for various application settings such as icon draw style, component include directories and network settings.
  • Status Bar - A bar at the bottom of the application showing useful information.
Icons Toolbar
Drag and drop Flowchart and State Diagram icons from the Command Icons toolbar onto the main flowchart window to create your flowchart application.
The Icons tab of the Project explorer window also contains Flowchart and State Diagram icons.
Embedded toolbar
App Creator toolbar
State Diagrams toolbar
Components Toolbar
This toolbar displays the component libraries that can be included in your program. Click on a component and it can be added onto either the Dashboard Panel or the System Panel and will be automatically connected to the microcontroller in the Chip view.
The properties of the component such as Pin connections, Configuration Parameters and other settings can be edited using the Properties window.
Embedded Toolbar
App Creator Toolbar
User Macros Toolbar
Debug Toolbar
Build Toolbar
Window Toolbar
Help Toolbar
Use this command to display and hide the Toolbar, which includes buttons for some of the most common commands in Flowcode, such as 'Open' (File > Open), 'Print' (File > Print) as well as Compiling the flowchart to Chip, HEX and C. You can even control simulation by running, pausing and stopping simulation using this toolbar as stepping into and over icons to simulate step by step.
11) Status Bar
4) Flowchart Window
System Panel
Compiler Messages
Video instructions
See the Accessing and Arranging Flowcode Panels video to learn how to organize the application to your preference and manage your work space effectively for optimal productivity and ease of access.
Watch the Toolbars and Buttons video to learn how to use each toolbar effectively as well as learning specific details and functions of each toolbar button.
Finally, view the Tabbed Flowcharts and Macros video to see how to control the interface when managing macros, from tabbed flowcharts and macros to viewing two macro flowcharts on one screen.
FXa7LJsRvAs}} 9c6FIZTfGmA}}
{{#ev:youtube|c0d47BSkKS4}}
