Flowcode Help Overview
Revision as of 14:52, 7 March 2014 by BenR (talk | contribs)
<sidebar>Sidebar: Flowcode Help Overview</sidebar>
Version 6
Title Description
New_in_Version_6 Introduction to new features in Flowcode 6 and other useful information
Chips List of supported microcontroller devices in Flowcode 6
Migrating_to_V6 Help and advise moving to v6 from an older version
Getting Started
Title Description
Activating_Flowcode Activating your Flowcode license
Opening_Flowcode Launching the Flowcode application
Creating_Flowcharts Creating your first Flowcode flowchart and see the options available
Selecting_a_Target_Chip Selecting the target microcontroller device
Configuring_the_Chip Configuring your device
Opening_an_Existing_Flowchart Opening an existing .FCFX Flowcode project file
Selecting_a_Template Opening a template project file
Saving_a_Flowchart Saving your program
Creating_Templates Creating your own templates
Closing_Flowcode Closing Flowcode
Flowcharts
Title Description
Icon_Properties Flowchart icons and their functionality
Adding_an_Icon_to_a_Flowchart Adding flowchart icons to your program
Editing_Icon_Properties Editing the properties of a flowchart icon
Adding_Comments_to_a_Flowchart Commenting your flowchart
Selecting_Icons Selecting icons on the flowchart
Flowchart_Editing_Functions Functions to make editing your flowchart easier
Printing_Flowcharts Printing out a flowchart
Macros
Title Description
Creating_a_New_Macro Creating a new flowchart macro or subroutine
Editing_and_Deleting_Macros Editing a macro and removing a macro from your program
Using_the_Project_Explorer Features of the project explorer designed to help simplify programming
Exporting_a_Macro Exporting a macro from within Flowcode
Importing_a_Macro Importing a macro into Flowcode
DLL_Support Changing the nature of a macro to instead call a external DLL function
Functions
Title Description
Mathematical_Functions Built in routines designed to help with mathematical operations such as Sin() and Float
String_Manipulation_Functions Built in routines designed to help with string manipulation
Undo_and_Redo Undo and Redo operations and shortcuts
Disabling_Icons Disabling flowchart icons to comment out sections of code
Icon_Annotations Icon annotations
Find_and_Replace Ability to search within your flowcode project to replace specific text with alternate text
Variables
Title Description
Creating_Variables How to create a variable
Variable_Types Variable types and their meanings
Editing_Variables How to edit a variable
Variable_Manager The Flowcode variable manager interface
Handles Handle variables and their function within the system
Typecasting Variable type casting, applications and usage
Panels
Title Description
Panels_Where_And_Why What the panels do and how they help you design your system
Dashboard_Panel More in depth information on the dashboard panel
System_Panel More in depth information on the system panel
Zooming_the_View Zooming in and out on panels
Camera_Control Controlling the camera looking at the panel
Object_Position Object positioning on the panels
Local_and_World_Space Local vs World space regarding coordinates
Object_Scale Objects and their scale
Object_Rotation Rotating objects
Working_With_Meshes Using meshes inside Flowcode
Tools and Views
Title Description
Tools_and_Views Various tools and views available inside Flowcode
Using_the_Data_Injector Data injectors and communications components
Using_the_Data_Console How to use the data console window in your programs
Using_the_Data_Scope How to use the data scope window in your programs
Using_the_Icon_Lists_Pane The icon lists pane
Project_Options Detailed help on the Project Options window
Global_Options Detailed help on the Global Options window
Web_Access_Panel The web access panel
Chip_View The chip view window
Analog_Window The analogue inputs window
Properties_Panel The properties panel
Simulation_Debugger The simulation debugger window
Component_Debugger The component debugger window
Supplementary_Code Supplementary code and its usage
Saving_Images_in_Flowcode Creating images of your flowchart source
Auto_Documentation Auto documentation features to speed up development
