Flowcode Help Overview
Revision as of 15:46, 7 March 2014 by BenR (talk | contribs)
<sidebar>Sidebar: Flowcode Help Overview</sidebar>
Version 6
  1. Version_6
Title Description
New_in_Version_6 Introduction to new features in Flowcode 6 and other useful information
Chips List of supported microcontroller devices in Flowcode 6
Migrating_to_V6 Help and advise moving to v6 from an older version
Getting Started
Title Description
Activating_Flowcode Activating your Flowcode license
Opening_Flowcode Launching the Flowcode application
Creating_Flowcharts Creating your first Flowcode flowchart and see the options available
Selecting_a_Target_Chip Selecting the target microcontroller device
Configuring_the_Chip Configuring your device
Opening_an_Existing_Flowchart Opening an existing .FCFX Flowcode project file
Selecting_a_Template Opening a template project file
Saving_a_Flowchart Saving your program
Creating_Templates Creating your own templates
Closing_Flowcode Closing Flowcode
Flowcharts
Title Description
Icon_Properties Flowchart icons and their functionality
Adding_an_Icon_to_a_Flowchart Adding flowchart icons to your program
Editing_Icon_Properties Editing the properties of a flowchart icon
Adding_Comments_to_a_Flowchart Commenting your flowchart
Selecting_Icons Selecting icons on the flowchart
Flowchart_Editing_Functions Functions to make editing your flowchart easier
Printing_Flowcharts Printing out a flowchart
Macros
Title Description
Creating_a_New_Macro Creating a new flowchart macro or subroutine
Editing_and_Deleting_Macros Editing a macro and removing a macro from your program
Using_the_Project_Explorer Features of the project explorer designed to help simplify programming
Exporting_a_Macro Exporting a macro from within Flowcode
Importing_a_Macro Importing a macro into Flowcode
DLL_Support Changing the nature of a macro to instead call a external DLL function
Functions
Title Description
Mathematical_Functions Built in routines designed to help with mathematical operations such as Sin() and Float
String_Manipulation_Functions Built in routines designed to help with string manipulation
Undo_and_Redo Undo and Redo operations and shortcuts
Disabling_Icons Disabling flowchart icons to comment out sections of code
Icon_Annotations Icon annotations
Find_and_Replace Ability to search within your flowcode project to replace specific text with alternate text
Variables
Title Description
Creating_Variables How to create a variable
Variable_Types Variable types and their meanings
Editing_Variables How to edit a variable
Variable_Manager The Flowcode variable manager interface
Handles Handle variables and their function within the system
Typecasting Variable type casting, applications and usage
Panels
Title Description
Panels_Where_And_Why What the panels do and how they help you design your system
Dashboard_Panel More in depth information on the dashboard panel
System_Panel More in depth information on the system panel
Zooming_the_View Zooming in and out on panels
Camera_Control Controlling the camera looking at the panel
Object_Position Object positioning on the panels
Local_and_World_Space Local vs World space regarding coordinates
Object_Scale Objects and their scale
Object_Rotation Rotating objects
Working_With_Meshes Using meshes inside Flowcode
Tools and Views
Title Description
Tools_and_Views Various tools and views available inside Flowcode
Using_the_Data_Console How to use the data console window in your programs
Using_the_Data_Scope How to use the data scope window in your programs
Using_the_Icon_Lists_Pane The icon lists pane
Project_Options Detailed help on the Project Options window
Global_Options Detailed help on the Global Options window
Web_Access_Panel The web access panel
Chip_View The chip view window
Analog_Window The analogue inputs window
Properties_Panel The properties panel
Simulation_Debugger The simulation debugger window
Component_Debugger The component debugger window
Supplementary_Code Supplementary code and its usage
Saving_Images_in_Flowcode Creating images of your flowchart source
Auto_Documentation Auto documentation features to speed up development
Components
Title Description
Common_Components Information on some of the more commonly used components
What_Is_a_Switch? Detailed information regarding the switch components
What_Is_an_LED? Detailed information regarding the LED components
What_Is_an_LCD? Detailed information regarding the LCD components
What_Is_a_7_Segment_Display? Detailed information regarding the 7Seg components
What_Is_a_Keypad? Detailed information regarding the keypad components
Selecting_Component_Macros Information on how to use component macros
Component_Help_Files How to get access to component help via Flowcode
Components Component help overview
Component_Properties Information on how to use component properties
Component_Tree Information regarding the component tree hierarchy
Replacing_a_Component Replacing one component with another
CAL_Components Overview of code abstraction layer components
DSP Overview of digital signal processing components
Using_the_Data_Injector Data injectors and communications components
Component_Directories Information on creating your own components directories
Editing_Key_Mappings Assigning keyboard presses to functionality during simulation
Component Creation
Title Description
Creating_a_Property How to create a property
Panel_Managers Overview of the component creation panel managers
Assigning_Code_to_an_Existing_Component Complementing or overriding an existing components functionality
Exercise_-_Create_an_LED_Component Creating a component from scratch
Base_Components The base components and their function
Using_A_Base_Component Creating a new component using a base
Title Description
Starting_Flowchart_Simulation Information on how to use the flowchart simulation
Simulating_Icons_Step_by_Step Stepping through icons
Breakpoints Using breakpoints
Changing_the_Speed_of_a_Simulation Changing the run speed of the simulator
Simulation_Only_Code Code designed to work only via the simulator
Simulation_Events Event macros used to provide more functionality to both simulation and compiled code
Chip Specifics
Title Description
Compiling_a_Flowchart_to_a_Chip Information on how to compile a flowchart into machine code
Internal_Oscillator Specifics on using an internal oscillator
Phase_Locked_Loop_(PLL) Specifics on using a PLL frequency multiplier
Custom_Interrupts Custom interrupts for your hardware
Debugging_Hardware_and_Software Tips on how to debug hardware and software
In_Circuit_Debugging Overview of the in circuit debugging (ICD) interface
In_Circuit_Test Overview of the in circuit test (ICT) interface
Supporting_Third_Party_Programming_Tools Using 3rd party programmers such as PICkit and Arduino
Viewing_Code_Output Viewing the code generated by Flowcode
Managing_Compiler_Options Overview of the compiler options settings
FCD_Data_Collection Chip definition files and how to collect data from them
Support
Title Description
FAQs Frequently asked questions
Reporting_a_Bug How to report a bug in Flowcode
Licensed_Compiler Compiler specifics and license agreement
Technical_Support Information on how to get further support
